10-02-2018 01:36 PM - edited 03-08-2019 04:17 PM
I noticed a warning condition on the uplink port of my Meraki MS220-8P indicating a very high rate of STP topology changes. This ports are set to Autonegotiate on both devices. Consequently, I reviewed the port statistic on the C3750 that is upstream from the Meraki switch and it seems to have a high number of undersized packets on port Gi0/2. The Receive Statistics on the 3750 show this:
Receive Statistics | ||||||||||
Interface | Port Description | Unicast | Multicast | Broadcast | Discarded | Alignment Errors | FCS Errors | Collision Fragments | Undersized | Oversized |
Fa1/0/1 | Voice and Data | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 |
Fa1/0/2 | Voice and Data | 710584723 | 2629671 | 185642 | 0 | 0 | 0 | 0 | 143110 | 0 |
Fa1/0/3 | Voice and Data | 394408 | 887667 | 16470 | 0 | 0 | 0 | 0 | 72538 | 0 |
Fa1/0/4 | bs-host-server | 1016540131 | 1904869 | 1203749 | 0 | 0 | 0 | 0 | 0 | 0 |
Fa1/0/5 | bs-rec-prn-1 | 22944694 | 8589 | 11561 | 0 | 0 | 0 | 0 | 0 | 0 |
Fa1/0/6 | Voice and Data | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 |
Fa1/0/7 | Voice and Data | 454235 | 887555 | 16470 | 0 | 0 | 0 | 0 | 36355 | 0 |
Fa1/0/8 | unifi controller | 786553217 | 12776671 | 11083220 | 0 | 0 | 0 | 0 | 0 | 0 |
Fa1/0/9 | Voice and Data | 126769276 | 2080574 | 3523657 | 0 | 0 | 0 | 0 | 155972 | 0 |
Fa1/0/10 | Voice and Data | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 |
Fa1/0/11 | bs-cc-mach | 1632 | 87 | 944 | 0 | 0 | 0 | 0 | 14 | 0 |
Fa1/0/12 | Voice and Data | 138128361 | 1778301 | 2832672 | 0 | 0 | 0 | 0 | 112236 | 0 |
Fa1/0/13 | Voice and Data | 156880973 | 2438887 | 1003599 | 0 | 0 | 0 | 0 | 175970 | 0 |
Fa1/0/14 | Voice and Data | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 |
Fa1/0/15 | Voice and Data | 51324416 | 15191 | 11214 | 0 | 0 | 0 | 0 | 0 | 0 |
Fa1/0/16 | Voice and Data | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 |
Fa1/0/17 | Voice and Data | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 |
Fa1/0/18 | 9653243 | 1692461 | 244376 | 0 | 0 | 0 | 0 | 59338 | 0 | |
Fa1/0/19 | Voice and Data | 131361772 | 2474746 | 168234 | 0 | 0 | 0 | 0 | 447506 | 0 |
Fa1/0/20 | Voice and Data | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 |
Fa1/0/21 | Voice and Data | 82496355 | 1105862 | 221769 | 0 | 0 | 0 | 0 | 44225 | 0 |
Fa1/0/22 | Voice and Data | 56913 | 1477 | 1331 | 0 | 0 | 0 | 0 | 0 | 0 |
Fa1/0/23 | Voice and Data | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 |
Fa1/0/24 | Voice and Data | 1045848 | 484532 | 6787785 | 0 | 0 | 0 | 0 | 0 | 0 |
Gi1/0/1 | Uplimk | 2058243015 | 980731341 | 1086412230 | 0 | 0 | 0 | 0 | 0 | 0 |
Gi1/0/2 | Uplimk | 338061381 | 128337514 | 7889033 | 0 | 0 | 0 | 0 | 167514 | 0 |
These two switches are connected via fiberoptic cable. The MTU on the Cisco is 1500. The Meraki should be the same as that's the default and I didn't change it. What could be causing this problem and how do I troubleshoot?
10-02-2018 03:02 PM
the undersized frames are most likely coming from the Meraki. Have you tried another port and cable to connect the Meraki to the 3750 ? Also, which IOS version are you running on the 3750 ?
10-02-2018 03:04 PM
I tried another SPF port on the Meraki but not another cable since that would require stringing a new fiber cable from another building. The 3750 is running 12.2(53).
10-02-2018 03:08 PM
try and set both ports to something other than auto negotiate...
10-02-2018 03:26 PM - edited 10-02-2018 03:27 PM
I tried setting the port on the Meraki to 1Gb forced (the only options I had were 1Gb and 1Gb forced). As soon as I did the switch stopped communicating. The only way I could reconnect was to change the SFP to the other port. The web interface for the C3750 crashes the applet when I try to access the port settings and when it opens there is no option available other than auto. I'm a little hesitant to change it via CLI because I don't want to cause another disconnection. It didn't make sense to me that forcing the 1Gb connection would cause a disconnect...
The techs at Meraki thought it might be because the Meraki supports RSTP and the Spanning Tree Mode from the STP settings on the C3750 appears to be rapid-pvst. Could that be the issue? The Protocol under the Bridge Parameters tab does indicate RSTP.
