Understanding a simple ACL question
hello0815
Hello guys,
I have a (most likely) very simple question about ACL's but I still manage to not figure out how stuff works.
My setup looks the following:
Cisco 3850, ip routing enabled
-Vlan 2 (Network 192.168.2.0/24, IP of the Router is 192.168.2.1)
-a PC with the IP 192.168.2.20
-a PC with the IP 192.168.2.222
-Vlan 3 (Network 192.168.3.0/24, IP of the Router is 192.168.3.1)
-a PC with the IP 192.168.3.20
-Vlan 4 (Network 192.168.4.0/24, IP of the Router is 192.168.4.1)
-a PC with the IP 192.168.4.20
To this point everything works fine, I can ping from everywhere to everywhere.
Now what I wanna achieve:
-PC 192.168.2.222 inside Vlan 2 should be allowed to send packets everywhere (=into the other VLANs) while using Port 9
-any other hosts inside Vlan 2 are not allowed to send packets anywhere with the Port 9
-everything else is fine for now and is allowed
My access-list looks the following:
ip access-list extended wol-acl
deny udp any any eq 9
permit udp host 192.168.2.222 any eq 9
This access-list is placed on interface Vlan 2:
interface Vlan2
mac-address blablabla
ip address 192.168.2.1 255.255.255.0
ip access-group wol-acl in
As soon as i place this ACL on interface Vlan2 nothing with Vlan2 works anymore:
I can't ping (and use any other ports etc.) from Vlan 3 to Vlan 2,
I can't ping (and use any other ports etc.) from Vlan 4 to Vlan 2,
I can't ping (and use any other ports etc.) from Vlan 2 to Vlan 3,
I can't ping (and use any other ports etc.) from Vlan 2 to Vlan 4.
Interactions between Vlan 3 and Vlan 4 are working fine.
What am I doing wrong? I only want to block any address except 192.168.2.222 to reach
the other Vlans while using Port 9. Everything else should be allowed (for now).
(I'm also aware that this WOL stuff is also requiring the ip-helper-addresses and other things like broadcast-redirect, but it's already failing
while setting up the ACL rule and breaking the whole network. You can replace Port 9 with every other Port.)
Any help is highly appreciated
Greetings from Germany
Hello
Try the following ACL
no ip access-list extended wol-acl
permit ip any any
int vlan 2
ip access-group wol-acl IN
Kind Regards
Paul
5 Replies 5
Richard Burts
The main issue is that in an acl by default the final statement is deny any any (anything that is not permitted is denied). Looking at your acl there is a single permit. So that is the only traffic that will work.
I note that the order of these statements is not correct
You need to permit the host before you deny all other traffic for port 9.
I would suggest that a good solution would be to add a new statement with permit ip any any
Rick
balaji.bandi
Agreed to add  like below should fix the issue :
deny udp any any eq discard
permit udp host 192.168.2.222 any eq discard
permit ip any any
BB
Hello
permit ip any any
int vlan 2
Kind Regards
Paul
hello0815
Hello guys,
first of all, thank you for your real quick help! That's awesome.
Thanks to @Richard Burts for explaining how the ACL acts and how it creates this "deny any any".
@balaji.bandi I tried your solution, but this didn't work for me. Probably because the "deny udp any any eq discard" is above the permit rule, like in my initial comment?
@paul driver This solution worked out for me. Works like a charm.
Thank you guys for helping me out and making me understand how things are working.
Glad you able to resolved the issue  sure we would have flipped the ACL permitt first and deny next - since deny was first time so it was denied... (i looked at my noted i changed your config, but pasted wrong one)
@paul driver  - good catch.
BB
