Understanding errors on PRTG, :(.. 3750X
joshhboss
Level 3
Level 3
Im trying to understand what these errors are that I get on PRTG. Ill post the commands I used to see what the switch tells me about the transceiver. Any insight is always appreciated.
mA: milliamperes, dBm: decibels (milliwatts), NA or N/A: not applicable.
++ : high alarm, +  : high warning, -  : low warning, -- : low alarm.
A2D readouts (if they differ), are reported in parentheses.
The threshold values are calibrated.
                              High Alarm  High Warn  Low Warn   Low Alarm
          Temperature         Threshold   Threshold  Threshold  Threshold
Port       (Celsius)          (Celsius)   (Celsius)  (Celsius)  (Celsius)
Gi1/1/4     30.5                90.0        85.0        -5.0      -10.0
           Voltage            Threshold   Threshold  Threshold  Threshold
Port       (Volts)            (Volts)     (Volts)    (Volts)    (Volts)
Gi1/1/4    3.31                  3.70        3.60        3.00       2.90
           Optical            High Alarm  High Warn  Low Warn   Low Alarm
           Transmit Power     Threshold   Threshold  Threshold  Threshold
Port       (dBm)              (dBm)       (dBm)      (dBm)      (dBm)
Gi1/1/4     -5.6                 1.0        -3.0        -9.5      -13.5
           Receive Power      Threshold   Threshold  Threshold  Threshold
Gi1/1/4     -7.8                 1.0        -3.0       -19.0      -23.0
Screen Shot 2022-07-07 at 3.36.19 PM.pngScreen Shot 2022-07-07 at 3.36.12 PM.pngScreen Shot 2022-07-07 at 3.36.05 PM.png
this for SFP interface, there are threshold different between each vendor,
https://community.fs.com/blog/check-sfp-module-optical-signal-strength.html
