Understanding MST Convergence
rasmus.elmholt
Level 7
Level 7
Hi All,
I have the following setup in CML:
  • SW1 is the Root Birdge
  • I have VLANs 1-20
  • All Switches have the same MST configuration and running in the same region.
When I shut down interface gi1/0/3 on SW3 the MST environment converges and uses Gi1/0/6 as the root port for some time until it falls back to Po1.
I cannot explain why as the internal cost is higher than using Po1.
Relevant configuration on SW3:
spanning-tree mode mst
spanning-tree mst configuration
 name CiscoSTD
 revision 1
interface GigabitEthernet1/0/2
 switchport mode trunk
 channel-group 1 mode active
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/6
 switchport access vlan 20
 switchport mode access
 spanning-tree portfast
interface GigabitEthernet1/0/7
interface Port-channel1
 spanning-tree mst 0 cost 10000
Debug when I shut down Gi1/0/3:
SW3(config-if)#do show span mst 0
##### MST0    vlans mapped:   1-4094
Bridge        address 5254.0002.8506  priority      32768 (32768 sysid 0)
Root          address 5254.0009.3a34  priority      24576 (24576 sysid 0)
              port    Po1             path cost     0
Regional Root address 5254.0009.3a34  priority      24576 (24576 sysid 0)
                                      internal cost 30000     rem hops 18
Operational   hello time 2 , forward delay 15, max age 20, txholdcount 6
Configured    hello time 2 , forward delay 15, max age 20, max hops    20
Interface                        Role Sts Cost      Prio.Nbr Type
Gi1/0/1                          Desg FWD 20000     128.1    P2p
Gi1/0/4                          Desg FWD 20000     128.4    P2p
Gi1/0/5                          Desg FWD 20000     128.5    P2p
Gi1/0/6                          Altn BLK 20000     128.6    P2p
Gi1/0/7                          Altn BLK 20000     128.7    P2p
Gi1/0/8                          Desg FWD 20000     128.8    P2p
Po1                              Root FWD 10000     128.2281 P2p
SW3(config-if)#int gi 1/0/3
SW3(config-if)#shut
SW3(config-if)#
*Jul 16 08:06:17.403: %LINK-5-CHANGED: Interface GigabitEthernet1/0/3, changed state to administratively down
*Jul 16 08:06:18.402: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/3, changed state to down
*Jul 16 08:06:19.764: MST[0]: Po1 state change forwarding -> blocking
*Jul 16 08:06:19.765: MST[0]: Gi1/0/1 state change forwarding -> blocking
*Jul 16 08:06:19.765: MST[0]: Gi1/0/4 state change forwarding -> blocking
*Jul 16 08:06:19.765: MST[0]: Gi1/0/5 state change forwarding -> blocking
*Jul 16 08:06:19.765: MST[0]: Gi1/0/8 state change forwarding -> blocking
*Jul 16 08:06:19.765: MST[0]: Gi1/0/6 state change blocking -> forwarding
*Jul 16 08:06:19.767: STP[0]: Generating TC trap for port GigabitEthernet1/0/6
              port    Gi1/0/6         path cost     0
                                      internal cost 50000     rem hops 17
Gi1/0/1                          Desg BLK 20000     128.1    P2p
Gi1/0/4                          Desg BLK 20000     128.4    P2p
Gi1/0/5                          Desg BLK 20000     128.5    P2p
Gi1/0/6                          Root FWD 20000     128.6    P2p
Gi1/0/8                          Desg BLK 20000     128.8    P2p
Po1                              Desg BLK 10000     128.2281 P2p
SW3(config-if)#
*Jul 16 08:06:34.765: MST[0]: Gi1/0/1 state change blocking -> learning
*Jul 16 08:06:34.765: MST[0]: Gi1/0/4 state change blocking -> learning
*Jul 16 08:06:34.765: MST[0]: Gi1/0/5 state change blocking -> learning
*Jul 16 08:06:34.765: MST[0]: Gi1/0/8 state change blocking -> learning
*Jul 16 08:06:34.765: MST[0]: Po1 state change blocking -> learning
Gi1/0/1                          Desg LRN 20000     128.1    P2p
Gi1/0/4                          Desg LRN 20000     128.4    P2p
Gi1/0/5                          Desg LRN 20000     128.5    P2p
Gi1/0/8                          Desg LRN 20000     128.8    P2p
Po1                              Desg LRN 10000     128.2281 P2p
SW3(config-if)#
*Jul 16 08:06:49.765: MST[0]: Gi1/0/1 state change learning -> forwarding
*Jul 16 08:06:49.765: MST[0]: Gi1/0/4 state change learning -> forwarding
*Jul 16 08:06:49.765: MST[0]: Gi1/0/5 state change learning -> forwarding
*Jul 16 08:06:49.765: MST[0]: Gi1/0/8 state change learning -> forwarding
*Jul 16 08:06:49.765: MST[0]: Po1 state change learning -> forwarding
*Jul 16 08:06:49.767: STP[0]: Generating TC trap for port Port-channel1
*Jul 16 08:07:36.649: MST[0]: Gi1/0/6 state change forwarding -> blocking
*Jul 16 08:07:36.649: MST[0]: Gi1/0/1 state change forwarding -> blocking
*Jul 16 08:07:36.649: MST[0]: Gi1/0/4 state change forwarding -> blocking
*Jul 16 08:07:36.649: MST[0]: Gi1/0/5 state change forwarding -> blocking
*Jul 16 08:07:36.649: MST[0]: Gi1/0/8 state change forwarding -> blocking
*Jul 16 08:07:36.650: STP[0]: Generating TC trap for port Port-channel1
*Jul 16 08:07:51.651: MST[0]: Gi1/0/1 state change blocking -> learning
*Jul 16 08:07:51.651: MST[0]: Gi1/0/4 state change blocking -> learning
*Jul 16 08:07:51.651: MST[0]: Gi1/0/5 state change blocking -> learning
*Jul 16 08:07:51.651: MST[0]: Gi1/0/8 state change blocking -> learning
*Jul 16 08:08:06.652: MST[0]: Gi1/0/1 state change learning -> forwarding
*Jul 16 08:08:06.652: MST[0]: Gi1/0/4 state change learning -> forwarding
*Jul 16 08:08:06.652: MST[0]: Gi1/0/5 state change learning -> forwarding
*Jul 16 08:08:06.652: MST[0]: Gi1/0/8 state change learning -> forwarding
SW3(config-if)#
SW3(config-if)#
At first I thought the issues was that the cost on po1 changed and MST had to do a recalculation, but I have manually configured it to 10.000 in the lab. And I still see the same issue.
I know it seems strange that we have SW3 and SW4 connected directly but IRL we have them connected to a production ring of siemens switches.
Can someone explain why the MST tree does not stay stable when I shut down one port in the LAG?
15 Replies 15
You mention two lab eve abd cml
Try which one support this command.
MHM
