Understanding SRR shape and limit
stretchlad
I just want to know if I have understood this correctly. If I have a port connected at 100Mb Full duplex with the following config:
srr-queue bandwidth shape 0 2 0 0
srr-queue bandwidth limit 18
Would this limit bandwidth to 18Mbit and also limit Queue 2 to 50% of 18Mbit which would be 9Mbit?
stretchlad
I have tested this in a lab and bot bandwidth shape and limit work off the physical speed rather than shape working off what limit is set at so my config was wrong. No need for a response now.
So, to clarify, when you tested, did you get 18M, because the srr-queue bandwidth shape cmd was 50% and the srr-queu bandwidth limit command was only 18%, or did the shape command override the limit cmd?
The shape command in this scenario as it is allows 1/2 or 50% of the physical bandwidth which was 100Mb so 50Mb. As I have a limit of 18Mb it would peak at 18Mb when in relaity I only wanted it to use 9Mb.
So bandwidth shape 0 11 0 0 would give 9Mb for queue 2 which is what I wanted to achieve. I still used the bandwidth limit to limit the overall port utilisation to 18Mb but wanted a cap on an individual queue also.
