Understaning VPC
opnineopnine
Level 7
Level 7
Hi all,
I have 2 7000 series, I have created  peer-link and peer-keepalive between them, I will connect this device to my MDS 9000 series, this ones have differente server connected to there ports.
What I don't understand is, I created the peer-link and keepalive between the 7000, when I connect from the 9000 to the 7000 do I have to use VPC per each server I have in the 9000 or I justa have to ues port-channles?
Thanks.
I think this was why there was confusion. In the original post you stated MDS 9000.
So the answer is yes. The Nexus 7700 and 9000 both support vPC and so you can build a double sided vPC between them.
The Quick Start Guide :: Virtual Port Channel (vPC) is an excellent reference and has an example on slide 19.
13 Replies 13
Reza Sharifi
You can simply connect the servers to the 9000 using Portchannels.  There is no need for VPC.
Hi all,
If I have this diagram and not shure if this is ok.
7700 <-vpc / peer-link and keepalive  / domain id 1-->7700
9000 <-vpc / peer-link and keepalive / domain id 2 -->9000
Now I want to conect with vpc from 9000 to 7700, should I make a new vpc with new domain or just a port channel?
thanks
When you say "9000" do you mean Cisco MDS 9000 i.e., a SAN switch or do you mean Cisco Nexus 9000 as you stated in your original post?
If you mean MDS 9000 series switch, then as per the previous comments, you would need to use a standard port-channel as vPC is not supported on this platform.
If you mean Nexus 9000, these do support vPC and so you could connect the Nexus 9000 vPC domain to the Nexus 7700 vPC domain using the "double side" vPC.
Hello Steve,
My 9000 are the C9372PX chassis, here I can use a peer-link to the 7700, with differet domain Id.?
thanks
As Steve said, you can connect each of the C9372PX switches to both 7700 switches.  This would be a double sided VPC.
So if I apply this will be ok ? this is from the 9000 to 7700
int e2/27 -28
 channel-group 100 mode active
int po100
 switchport
 switchport mode trunk
 spanning-tree port type normal
 vpc 100
Correct. As I said, slide 19 of the quick start guide I linked to previously has a working example.
Hi all
I just did the configuration recommended and now have this error.
vPC status
id   Port      Status Consistency Reason                  Active vlans
20   Po20      down*  failed      vpc port channel           -
                                  mis-config due to vpc
                                  links in the 2 switches
                                  connected to different
                                  partners
Any ideas?
It's not clear which switch you ran this command from, but essentially it's telling you that the Link Aggregation (LAG) System ID being received from the two devices connected to the interfaces that are members of port-channel 20 is different on each interface. As you have port-channel 20 configured as a vPC, then it expects the ID to the same.
If you run the command show lacp neighbor interface port-channel 20, the Partner System ID see on all the physical interfaces should be same.
In my setup I have a vPC domain formed from switch1 and switch2 connected via eth1/1 and eth1/2 to a second vPC domain formed from switch3 and switch4. In the following you can see the LAG Partner System ID is the same on eth1/1 and eth1/2 of both switch1 and switch2:
switch1# sh lacp nei int po11
Flags:  S - Device is sending Slow LACPDUs F - Device is sending Fast LACPDUs
        A - Device is in Active mode       P - Device is in Passive mode
port-channel11 neighbors
Partner's information
            Partner                Partner                     Partner
Port        System ID              Port Number     Age         Flags
Eth1/1      32667,0-23-4-ee-be-b   0x101           835         SA
            LACP Partner           Partner                     Partner
            Port Priority          Oper Key                    Port State
            32768                  0x800b                      0x3d
Eth1/2      32667,0-23-4-ee-be-b   0x4101          768         SA
            32768                  0x800b                      0x3d
switch2# sh lacp nei int po11
Eth1/1      32667,0-23-4-ee-be-b   0x102           879         SA
            32768                  0x800b                      0x3d
Eth1/2      32667,0-23-4-ee-be-b   0x4102          812         SA
            32768                  0x800b                      0x3d
The Partner System ID should match the System MAC address of the downstream devices, and if those devices are also running vPC, the System ID should be the MAC address seen when you run the show vpc role command on those downstream devices. For example:
switch3#  sh vpc role
vPC Role status
vPC role                        : primary
Dual Active Detection Status    : 0
vPC system-mac                  : 00:23:04:ee:be:0b
vPC system-priority             : 32667
vPC local system-mac            : 54:7f:ee:0c:18:3c
vPC local role-priority         : 1
switch4# sh vpc role
vPC Role status
vPC role                        : secondary
vPC local system-mac            : 54:7f:ee:10:ce:7c
vPC local role-priority         : 2
Are you able to post a diagram of the setup showing the interfaces that connect between the four switches? Also can you post the output of the following commands from all four switches i.e., both the Nexus 7700 and Nexus 9000
  • show run vpc
  • show port-ch summary
  • show cdp nei
Please check the link below. You are able to config all switches in one VPC domain..
You can find all cautions related to one VPC domain or and two VPC domains.
http://www.cisco.com/c/dam/en/us/td/docs/switches/datacenter/sw/design/vpc_design/vpc_best_practices_design_guide.pdf
You need to configure a VPC on 7000-1 and 7000-2 for MDS connection( suppose MDS has one link connected to each 7000)
Configuration looks like this.
7000-1
int po100
switch mode trunk
vpc 100
int e1/3   [ connected to MDS]
channel-group 30 mode active
7000-2
int po100
switch mode trunk
vpc 100 [Connected to MDS]
int e1/3
On MDS, you need to create just a regular port-channel  for 7000-1 and 7000-2 connection
and some other regular port-channels for your server connections . ( one for each server)
As you can see the term of VPC  is only used on 7000. Your MDS sees VPC peers as a single device.
Hope it helps.
Masoud
Ganesh Hariharan
Hi all,
Thanks.
As suggested , Create vPC domain for two N7k and you can create Multi chasis ether channel with MDS to N7k switches for uplink connectivity.
Considering you have single MDS switch then from server to MDS you can go with simple port channel.
Check out the below link on vPC design which can be helpful for your implementation.
http://www.cisco.com/c/en/us/products/collateral/switches/nexus-9000-series-switches/guide-c07-733228.html
Hope it Helps..
-GI
Rate if it Helps
