Undoing running configuration
cisco_lite
What is the safest way to undo running configuration in cisco switches and routers.
17 Replies 17
mlund
Level 7
Level 7
I think there has been another thread about this, but I can't find it. However I copied a bit of it, and it is using the "config replace" and "archive" commands.
example
! this is better than "reload in 2"
r#show archive
There ara currently 4 archive configurations saved.
The next archive file will be named disk0:/config-archive-4
Archive # Name
1 disk0:/config-archive-1
2 disk0:/config-archive-2
3 disk0:/config-archive-3 <- Most recent
r#config replace disk00:/config-archive-3 time 120
... config changes are made
... your config change work OK
r#no config replace disk0:config-archive-3
here is a link describing it.
http://www.cisco.com/en/US/docs/ios/12_3t/12_3t7/feature/guide/gtrollbk.html
/Mikael
In the given link, it is mentioned
'When using the configure replace command, you must specify a saved Cisco IOS configuration as the replacement configuration file for the current running configuration'
Should a configure replace be followed by copy run start.
That depends of what you are trying to achive.
If the replaced config is not the same as in the startup-config, if a reload then occurs (by reload or by power-outage) then the stratup-config will be in place, and the replaced config will be lost.
If the replaced config is the one You want to be active even after a reboot, then a copy run start will be the right thing to do.
/Mikael
