Uneven number of interfaces on an etherchannel?
sonikbaby
Just a quick question, is ok to have 3 interfaces on an etherchannel set to LACP.
Thanks.
Bilal Nawaz
Hello, yes its OK to do this. The maximum you can have is up to 8 that are 'active'
Link Aggregation Control Protocol (LACP) is part  of an IEEE specification (802.3ad) that allows you to bundle several  physical ports together to form a single logical channel. LACP allows a  switch to negotiate an automatic bundle by sending LACP packets to the  peer. It performs a similar function as Port Aggregation Protocol (PAgP)  with Cisco EtherChannel.
http://www.cisco.com/en/US/tech/tk389/tk213/tk833/tsd_technology_support_sub-protocol_home.html
http://en.wikipedia.org/wiki/EtherChannel
Hope this helps
Bilal
Please rate useful posts and remember to mark any solved questions as answered. Thank you.
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
Bilal Nawaz
Hope this helps
Bilal
Thanks!
