04-29-2013 09:28 PM - edited 03-07-2019 01:05 PM
I have a customer who wishes to implment QoS on a 2821 router with ios 12.4(15).T8. They want to prioritize outbound and inbound Citrix traffic up to 128 kbps out the Internet interface. I have ben given the Citrix server IP address and have the application ports as well. If Citrix is not using this bandwidth, other applications need to be able to use it. What would be the simplest approach to implement this?
thanks in advance
04-29-2013 09:53 PM
you can modify this configuration as per your reqirement.. you can define ip precedence value 5 to your citrix traffic and for any other traffic just give ip precedence value of 0
access-list 100 permit tcp any any eq 1720
! class-map voip match access-group 100 ! policy-map MQC class voip set ip precedence 5 class class-default set ip precedence 0 !
interface FastEthernet0/0 no ip address duplex auto speed auto service-policy input MQC
04-29-2013 10:30 PM
Thank you for the very quick response and feedback, much appreciated.
This was the road I was going down, and wanted to be sure I was going with the most efficient method.
So, to allocate a percentage of the total bandwidth to the citrix class, could I then add the following lines (I assumed the total bandwidth was 1 Mbps, so 13% is roughly 128 kbps)?:
class-map citrix
policy-map MQC
class citrix
set ip precedence 5
bandwidth percent 13 class class-default
set ip precedence 0
fair-queue Again, thank you very much.
Andrew
04-29-2013 11:31 PM
Hi Andrew,
You can also look at NBAR by matching the ICA protocol directly. I've looked at a 2821 running 12.4(25f) to get this config.
Something like:
class-map citrix
match protocol citrix
policy-map citrix-map
class citrix
bandwidth 128
class class-default
fair-queue
If you want to get more specific, you can stipulate the IP of the server as well.
!or depending on traffic direction
class-map match-all citrix
Also, if this is on the Internet interface, you needn't worry about marking the packets. As far as I know the Internet doesn't listen to TOS. Certainly the providers i've used in the past don't.
If you use the percentage key-word rather than bandwidth in the policy-map, don't forget to put the bandwidth statement on the Interface. Also ensure the service-policy is applied.
Enjoy.
Brad
04-30-2013 09:34 AM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
You cannot really prioritize inbound. You might police non-Citrix traffic to allow Citrix 128 Kbps, but then when Citrix is not using its bandwidth, that bandwidth is unavailable. Also, even thought other traffic might be policed to provide 128 Kbps, you really cannot guarantee that because the policing is after the traffic ingresses.
Outbound, it's pretty easy. For example, perhaps:
class-map match-any Citrix
match protocol Citrix
policy-map Sample
class Citrix
priority 128 (or it might be 128000; don't recall if parameter is bps or Kbps)
Instead of using LLQ, you might use a high % bandwidth statement with a shaper, e.g.:
policy-map Sample2
class Citrix
bandwidth percentage 99
shape average 128000
You also might want to consider using NBAR with Citrix subtypes, so you don't give the same high priority to Citrix printing or disk copying.
