Unicast flood on 3750
Hi. There is a unicast flood on 3750 killing slow modem links. How to determine source MAC address of flooder?
Is there a rate limit feature for it?
I know how to block it completely on port-level, but it breaks normal network operation. (when port goes down for some reason, it's learned MACs got flushed and since other hosts know MACs, they keep flooding untill their arp caches expire).
11 Replies 11
Use storm-control unicast
Smitesh
PS: Please rate helpful posts.
I tried that. It seems to be blocking all unicast traffic, not just flooding.
How much limit you imposed ??
Limit argument take input as percent which you need to allow.
100 mean no limit impose and 0 means total traffic will be blocked.
Alternatively it can also be specificed as pps or bps.
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750x_3560x/software/release/12.2_53_se/configuration/guide/swtrafc.html#wp1085979
and which interface you used the command.
Smitesh
I tried "bps 1m" on all interfaces at once. Almost lost control over switch, turned it back off.
Just checked it a lab, using "storm-control unicast" affects ALL unicast traffic from that interface, not just flood one. So in general LAN it is useless.
Correct.
That why it is important to chose the limit very carefully.
Basically this command will rate-limit the number of unicast packet which you can send.
If the flood is unknown unicast then, as Peter suggested switchport block unicast is what you need.
Smitesh
This might be good for enduser port, but not for uplink to another switch or bridge. If that interface looses it's MAC table for some reason then entire segment behind it will loose it's connectivity for a long time, while host's ARP caches times out or they send something outside their segment.
PS: i've rebooted switch and problem gone for a while. It's probably buggy IOS or faulty hardware.
There is a feature called switchport block unicast - would perhaps this be helpful?
I've already described what happens if this command is in effect.
Here is what i found while using port mirror:
tmn-rosch-3750#ping 10.131.12.251
Sending 5, 100-byte ICMP Echos to 10.131.12.251, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/9 ms
tmn-rosch-3750#sho arp | inc 10.131.12.251
Internet  10.131.12.251         141   0004.23b7.f983  ARPA   Vlan1
tmn-rosch-3750#sho mac address-table | inc 0004.23b7.f983
tmn-rosch-3750#
how could that be?
Seems like a bug with switch.
tmn-rosch-3750#sho ver
Cisco IOS Software, C3750 Software (C3750-ADVIPSERVICESK9-M), Version 12.2(44)SE2, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Thu 01-May-08 15:42 by antonino
Image text-base: 0x00003000, data-base: 0x01840000
ROM: Bootstrap program is C3750 boot loader
BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M) Version 12.2(25r)SEC, RELEASE SOFTWARE (fc4)
tmn-rosch-3750 uptime is 26 weeks, 3 days, 5 hours, 38 minutes
System restarted at 12:13:12 TMN Mon Aug 27 2012
System image file is "flash:c3750-advipservicesk9-mz.122-44.SE2/c3750-advipservicesk9-mz.122-44.SE2.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C3750-48TS (PowerPC405) processor (revision M0) with 0K/12280K bytes of memory.
Processor board ID CAT1028NL8E
Last reset from power-on
15 Virtual Ethernet interfaces
48 FastEthernet interfaces
4 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 00:0A:B8:C1:5B:00
Motherboard assembly number     : 73-9680-10
Power supply part number        : 341-0028-02
Motherboard serial number       : CAT10267XYV
Power supply serial number      : DTH10232CMB
Model revision number           : M0
Motherboard revision number     : A0
Model number                    : WS-C3750-48TS-S
System serial number            : CAT1028NL8E
SFP Module assembly part number : 73-7757-03
SFP Module revision Number      : A0
SFP Module serial number        : CAT10276AQ4
Top Assembly Part Number        : 800-25854-02
Top Assembly Revision Number    : D0
Version ID                      : V05
CLEI Code Number                : CNMV300CRE
Hardware Board Revision Number  : 0x01
Switch Ports Model              SW Version            SW Image
*    1 52    WS-C3750-48TS      12.2(44)SE2           C3750-ADVIPSERVICESK9-M
Configuration register is 0xF
tmn-rosch-3750#sho mac address-table count
Total Mac Address Space Available: 1960
