Unicast to multiple Unicast conversion
torsten.brink
Level 2
Level 2
Hi NetPro´s,
I´m actually working on a Intercom solution that should be able to broadcast the UDP RTP stream to different locations (over the WAN).
Therefore I already tested a behaviour (with NAT) to convert a single UDP stream (that will be send over the WAN) to the destination edge and then convert the UDP stream into a multicast address, where the IP phones are able to receive the stream, here´s the flow:
        conversion
<Phone> --unicast--> <WAN Edge> --unicast--> <WAN Edge> --multicast--> <Phone>
|Chicago|                      |Chicago|                           | NYC |                            | NYC |
So this above mentioned behaviour works fine..
However, in the second level I want to be able addressing many other locations (e.g. NYC, Boston, etc.), but I´m only able to place one unicast stream. Is there a mechanisms that is able to split one unicast stream into multiple unicast streams?
It should look like this:
                                  conversion                     conversion
|Chicago|                      |Chicago|    |                      | NYC |                            | NYC |
                                                     |--unicast--> <WAN Edge> --multicast--> <Phone>
        | Boston |                            | Boston|
Would be great to hear your idea´s...
Cheers
Torsten.
0 Replies 0
