unknown protocol drops on Cisco 3850 switches
esturao
All -
I have a Layer 2 stack of Cisco 3850 switches with the latest sw image. The switches have a large amount of printers connected to it since it is a County Publishing facility. When I look at the some of the switch ports where users are complaining of print jobs being delivered intermittently I see unknown protocol drops. I removed DTP and CDP after reviewing some of the information from the support forums and the problem continues to persist. The printer port is TCP LPD 515. I performed a packet capture and I am unable to find the problem.
See config info below. Please help.
Switch Ports Model              SW Version        SW Image              Mode
*    1 56    WS-C3850-48P       03.07.00E         cat3k_caa-universalk9 INSTALL
     2 56    WS-C3850-48P       03.07.00E         cat3k_caa-universalk9 INSTALL
Current configuration : 253 bytes
interface GigabitEthernet2/0/18
 description to B18 Xerox Nuvera Printer
 switchport access vlan 209
 switchport mode access
 switchport nonegotiate
 power inline never
 speed 1000
 duplex full
 no cdp enable
 spanning-tree portfast
end
X001#sh int g2/0/18
GigabitEthernet2/0/18 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 00e1.6d38.f912 (bia 00e1.6d38.f912)
  Description: to B18 Xerox Nuvera PrinterA 10.60.10.20
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
  Keepalive set (10 sec)
  Full-duplex, 1000Mb/s, media type is 10/100/1000BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input 00:00:02, output never, output hang never
  Last clearing of "show interface" counters 00:32:17
  Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute output rate 1000 bits/sec, 1 packets/sec
     2212 packets input, 473000 bytes, 0 no buffer
     Received 102 broadcasts (0 multicasts)
     0 watchdog, 0 multicast, 0 pause input
     4148 packets output, 419599 bytes, 0 underruns
     32 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
0 Replies 0
