Showing results forĀ
Search instead forĀ
Did you mean:Ā
Unknown protocol drops on GigabitEthernet0/1 interface
We are using  3825 Cisco router with IOS version 12.4(24)T2.
The unknown protocol drops on our GigabitEthernet0/1 interface is increasing.
This interface is connected to our modem.
What could be causing this unknown protocol drops?
Please advise.
cnshaccent-gw-2#sh int GigabitEthernet0/1
GigabitEthernet0/1 is up, line protocol is up
  Hardware is BCM1125 Internal MAC, address is ffff.ffff.ffff (bia ffff.ffff.ffff)
  Internet address is 10.201.72.110/30
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
     reliability 255/255, txload 1/255, rxload 3/255
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, media type is RJ45
  output flow-control is XON, input flow-control is XON
  Last input 00:00:00, output 00:00:00, output hang never
  Last clearing of "show interface" counters 5d01h
  Input queue: 0/75/0/2236 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 1197000 bits/sec, 192 packets/sec
  5 minute output rate 602000 bits/sec, 198 packets/sec
     49064806 packets input, 671449535 bytes, 0 no buffer
     Received 204175 broadcasts, 0 runts, 0 giants, 0 throttles
     0 watchdog, 217883 multicast, 0 pause input
     50635047 packets output, 1626883298 bytes, 0 underruns
     204175 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
Richard Burts
We see the symptoms of unknown protocol drops sometimes when a router interface is connected to a switch and the switch is sending something like Dynamic Trunking Protocol or something similar for switch operation. I am not sure what kind of modem you are connected to but I suspect that there is some service protocol that it is running that is sending packets out the interface that are not routable IP and the router is treating them as unknown protocol and dropping them.
Rick
Rick
