05-24-2016 12:03 AM - edited 03-08-2019 05:54 AM
Hello guys,
I have an issue two C3850 switches. One of C3850 is in the production and operates normally - second one I am adding to the production. Previously those switches were stacked - however I DO NOT want them to stuck. I want them to operate as two stand-alone switches.
The issue is when I connect second C3850 to the production. I does not have any configuration in it, just trunk link which is connected to router.
As soon I connect it, second switch stop working. To clean up all other background issue, I reset second switch to the factory settings. But issue still exist.
I suspect issue with stuck - second switch things that it is a active and other switch is standby.
C3850-1#sh switch
Switch/Stack Mac Address : 9c57.ad9f.4300 - Local Mac Address
Mac persistence wait time: Indefinite
H/W Current
Switch# Role Mac Address Priority Version State
*1 Active 9c57.ad9f.4300 1 V06 Ready
C3850-2#show switch
Switch/Stack Mac Address : 9c57.ad9f.5a00 - Local Mac Address
H/W Current
*1 Active 9c57.ad9f.5a00 1 V06 Ready
How can I fix it?
05-24-2016 12:32 AM
when a standalone stack able switch is not stacked it will always show as active thats normal what you see above , when you took it out of the stack did you configure it fully as standalone as only the master probably had the config when it was stacked between the pair , so you would need to reconfigure it completely as a stand alone switch , only the ports would have configuration after removing it from stack
what configuration is currently on it and what logs alerts etc do you get when its connected to the network , are you consoled in when you do this as it will show more information of whats going wrong
05-24-2016 02:24 AM
When I consoled to it and connect that to network, it shows absolutely nothing. no logs, whatever. Same with other switch.
I configured C3850-2 switch as stand-alone switch by erase config, reset switch to its factory by holding mode bottom 7 sec and issue command:
no switch 2 provision ws-c3850-48t
No configuration sits on it except I configured 10GB link as trunk. So interfaces nr beginning now from 1/0/1 - 46(previously it was 2/0/1-46).
Also I did no change to C3850-1 switch - interfaces are listed 1/0/1 - 46 so I did not reset any config.
" you would need to reconfigure it completely as a stand alone switch "
Do you mean that switch C3850-1 I should configure as stand-alone switch as well? does it mean I should factory reset that as well?
Now it shows provision that there is only one switch:
C3850-1#show run | i provisi
switch 1 provision ws-c3850-48t
05-24-2016 02:31 AM
what exactly is the issue ?
you made 2 switches standalone that's fine , switches should have separate configuration on them now there standalone , is it your trunk is not working when you connect it to the network ? can you post the configs of the switches and what your connecting between are you just trunking these switches together
you dont need to factory reset the switches for them to be standalone but when you reomve a slave switch from a stack it will only have port configuration , it wont have security,routing etc still configured
05-24-2016 03:29 AM
"what exactly is the issue ?"
issue is when I connect C3850-2 switch (which was previosly slave), C3850-1 stop to operate (mng vlan is down, it does not forward a frames any more).
" is it your trunk is not working when you connect it to the network "
Trunk is working fine, all trunk interfaces shown as connected.
"can you post the configs of the switches"
Config is complex, it contains QoS, pearser view and other not related to topic issues. Let me know what command output do you want me to paste it.
05-24-2016 03:53 AM
I also add that I replaced switch C3850-2 with C3560X - I connect it to the network with similar config(one trunk link and same vlans) - there is NO ISSUE at all.
So it is definitively something going on with C3850-2 and relation between other C3850-1 which is incredibly odd.
05-24-2016 04:36 AM
is spanning tree blocking the mgmt vlan when its connected ,
show spanning-tree vlan x
the vlan should only go down if there are no stp instances for it , or if there are no access ports but as its mgmt there wont be any access ports assigned to it so that only leaves stp really , if the vlan goes down there should also be logs to indicate why
check the show int trunk between the switches when its connected make sure everything is forwarding on it
05-24-2016 05:13 AM
hi Mark,
Span should not be an issue - if it was, I would see logs that mng vlan is blocked, anyway - as I said - I connected other switch, but different platform (C3650) with same vlan config and trunk config - and I did not see any issue with that switch.
05-24-2016 06:20 AM
Hi!
Do you have VTP configured in the switches?
Regards!
JC
05-24-2016 08:00 AM
Hello
Did you power off the switch before you disconnected it( this is an important step) and when you unprovisioned it was it from Sw1 ( the master)
When you erased the Nvram did you also delete the vlan.dat file from flash?
Can you please post the running config of the now standalone switch without it connected up to any other switch
sh vlan bri
sh vtp status
sh version
res
Paul
05-24-2016 11:53 PM
Hi Paul,
I actually did not power it off. But I did that this morning. I did:
1) erase config
2) delete vlan.dat
3) reload switch
4) unplug power cable
5) configure single trunk link to router,disabled routing, vtp mode set to transparent
6) connect to the network by enabled 10GB interface
7) second switch C3850-1 which was master, intermediately stopped responding for pings
😎 there is no l2 connection beetween switches
9) no logs indicate any error on both switches
here is an output of commands you requested:
Switch# sh vlan br
VLAN Name Status Ports
1 default active Gi1/0/1, Gi1/0/2, Gi1/0/3
Gi1/0/4, Gi1/0/5, Gi1/0/6
Gi1/0/7, Gi1/0/8, Gi1/0/9
Gi1/0/10, Gi1/0/11, Gi1/0/12
Gi1/0/13, Gi1/0/14, Gi1/0/15
Gi1/0/16, Gi1/0/17, Gi1/0/18
Gi1/0/19, Gi1/0/20, Gi1/0/21
Gi1/0/22, Gi1/0/23, Gi1/0/24
Gi1/0/25, Gi1/0/26, Gi1/0/27
Gi1/0/28, Gi1/0/29, Gi1/0/30
Gi1/0/31, Gi1/0/32, Gi1/0/33
Gi1/0/34, Gi1/0/35, Gi1/0/36
Gi1/0/37, Gi1/0/38, Gi1/0/39
Gi1/0/40, Gi1/0/41, Gi1/0/42
Gi1/0/43, Gi1/0/44, Gi1/0/45
Gi1/0/46, Gi1/0/47, Gi1/0/48
Gi1/1/1, Gi1/1/2, Te1/1/3
Te1/1/4
1002 fddi-default act/unsup
1003 token-ring-default act/unsup
1004 fddinet-default act/unsup
1005 trnet-default act/unsup
Switch#sh vtp status
VTP Version capable : 1 to 3
VTP version running : 1
VTP Domain Name :
VTP Pruning Mode : Disabled
VTP Traps Generation : Disabled
Device ID : 9c57.ad9f.5a00
Configuration last modified by 0.0.0.0 at 0-0-00 00:00:00
Feature VLAN:
VTP Operating Mode : Transparent
Maximum VLANs supported locally : 1005
Number of existing VLANs : 5
Configuration Revision : 0
MD5 digest : 0x57 0xCD 0x40 0x65 0x63 0x59 0x47 0xBD
0x56 0x9D 0x4A 0x3E 0xA5 0x69 0x35 0xBC
Switch#sh ver
Cisco IOS Software, IOS-XE Software, Catalyst L3 Switch Software (CAT3K_CAA-UNIVERSALK9-M), Version 03.07.02E RELEASE
SOFTWARE (fc1)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Tue 21-Jul-15 12:51 by prod_rel_team
Cisco IOS-XE software, Copyright (c) 2005-2015 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.
(http://www.gnu.org/licenses/gpl-2.0.html) For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
BOOTLDR: CAT3K_CAA Boot Loader (CAT3K_CAA-HBOOT-M) Version 1.18, RELEASE SOFTWARE (P)
Switch uptime is 4 minutes
Uptime for this control processor is 8 minutes
System returned to ROM by reload
System image file is "flash:packages.conf"
Last reload reason: Reload due to Express Setup
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Level: Ipbase
License Type: Permanent
Next reload license Level: Ipbase
cisco WS-C3850-48T (MIPS) processor with 4194304K bytes of physical memory.
Processor board ID FCW1938D16R
1 Virtual Ethernet interface
52 Gigabit Ethernet interfaces
4 Ten Gigabit Ethernet interfaces
2048K bytes of non-volatile configuration memory.
250456K bytes of Crash Files at crashinfo:.
1609272K bytes of Flash at flash:.
0K bytes of Dummy USB Flash at usbflash0:.
0K bytes of at webui:.
Base Ethernet MAC Address : 9c:57:ad:9f:5a:00
Motherboard Assembly Number : 73-16296-07
Motherboard Serial Number : FOC19383G4J
Model Revision Number : X0
Motherboard Revision Number : B0
Model Number : WS-C3850-48T
System Serial Number : FCW1938D16R
Switch Ports Model SW Version SW Image Mode
* 1 56 WS-C3850-48T 03.07.02E cat3k_caa-universalk9 INSTALL
Configuration register is 0x102
Switch#sh run
Building configuration...
Current configuration : 3449 bytes
! Last configuration change at 23:43:27 UTC Tue May 24 2016
version 15.2
no service pad
service compress-config
hostname Switch
boot-start-marker
boot-end-marker
vrf definition Mgmt-vrf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
no aaa new-model
qos queue-softmax-multiplier 100
vtp mode transparent
diagnostic bootup level minimal
spanning-tree mode pvst
hw-switch switch 1 logging onboard message level 3
redundancy
mode sso
class-map match-any non-client-nrt-class
policy-map port_child_policy
class non-client-nrt-class
bandwidth remaining ratio 10
interface GigabitEthernet0/0
vrf forwarding Mgmt-vrf
no ip address
negotiation auto
interface GigabitEthernet1/0/1
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
interface GigabitEthernet1/0/25
interface GigabitEthernet1/0/26
interface GigabitEthernet1/0/27
interface GigabitEthernet1/0/28
interface GigabitEthernet1/0/29
interface GigabitEthernet1/0/30
interface GigabitEthernet1/0/31
interface GigabitEthernet1/0/32
interface GigabitEthernet1/0/33
interface GigabitEthernet1/0/34
interface GigabitEthernet1/0/35
interface GigabitEthernet1/0/36
interface GigabitEthernet1/0/37
interface GigabitEthernet1/0/38
interface GigabitEthernet1/0/39
interface GigabitEthernet1/0/40
interface GigabitEthernet1/0/41
interface GigabitEthernet1/0/42
interface GigabitEthernet1/0/43
interface GigabitEthernet1/0/44
interface GigabitEthernet1/0/45
interface GigabitEthernet1/0/46
interface GigabitEthernet1/0/47
interface GigabitEthernet1/0/48
interface GigabitEthernet1/1/1
interface GigabitEthernet1/1/2
interface GigabitEthernet1/1/3
interface GigabitEthernet1/1/4
interface TenGigabitEthernet1/1/1
interface TenGigabitEthernet1/1/2
interface TenGigabitEthernet1/1/3
switchport mode trunk
interface TenGigabitEthernet1/1/4
interface Vlan1
no ip address
shutdown
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
line con 0
stopbits 1
line aux 0
line vty 5 15
wsma agent exec
profile httplistener
profile httpslistener
wsma agent config
wsma agent filesys
wsma agent notify
wsma profile listener httplistener
transport http
wsma profile listener httpslistener
transport https
ap group default-group
end
Switch#
05-25-2016 12:36 AM
05-25-2016 02:06 AM
unfortunately, IOS upgrade to the newest version did not help.Issue still exist.
05-25-2016 02:05 AM
