Unusual ARP packets from clients
MH311x
Hello everybody!
I am experiencing an unusual behavior in our network. Unfortunetely I have no idea what could cause this problem.
We are using Dyamic ARP Inspection on most of our VLANs. Since 7 days there are several clients (on different sites) which send more than 15 ARP packets in 1 second. That causes the port to go in err-disabled state.
DAI is now active for several months and there were no problems in the past. From one day to the other, many clients are having this issue. The packets are sent when booting the client, so after booting, the port goes in err-disabled state.
In most cases the clients were sending 16 ARP packets ... the treshhold for err-disabled was 15 packets. I've increased the treshhold to 25 packets but still some clients send more packets than this.
Has anyone ever experienced something like this? My "Windows guys" said there was no update or changes of drivers or the network stack.
Is there a problem in setting the treshhold higher?
5 Replies 5
balaji.bandi
what device and IOS code running here?
if this is all over the network and any specific switch ( take that one, look what is that ARP entries ? is this legitimate ?)
BB
MH311x
@balaji.bandi the problem appears on different models. Our most used devices are C2960X running on 15.2.(7)E4.
But e.g. also on an old Catalyst 4506-E.
I could try to capture the ARP packets, but it will be a little bit tricky since this doesnt occur on every boot of the client.
is this happends only when end device reboot ? why end device need to have so many MAC address ? until they run any hyper-v inside ?
BB
BB asks an interesting question about why an end device would need multiple IP addresses. I wonder whether it is that the end device is dong arp for multiple IP addresses, or is the end device doing multiple arp for the same IP address?
Rick
https://docs.microsoft.com/en-us/troubleshoot/windows-server/networking/address-resolution-protocol-arp-caching-behavior
check above link for ARP caching in Win
for why it happened now It seem that you large your network.
