Upgrade 2620XM to two FastEthernet interfaces
air2air
I have a 2620XM with (obviously) one FastEthernet interface. However, I'd like to setup a bridging firewall and will need two FastEthernet interfaces for that. What is the best way to upgrade the router? Which module would be the best for coupling with the existing one for bridging purposes?
Andrey
paddyxdoyle
Level 6
Level 6
You need to look at a NM-1FE2W as Cisco have stopped making the NM-1FE dedicated modules.
This module requires 12.2(8)T as the minimum IOS version and 32 MB DRAM, the IOS also supports bridging
PJD
Rather than vesting on a network module worth 1500-2000 dollars, i would suggest trading in the Cisco 2620 and get a 2801 or 2811. It will come upto the same price..
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
Thanks guys. I'm going to try to get a NM-1FE. It looks like I can get it from eBay for $200. This is a low budget project.
