Upgrade 6500 with Redundant Sup
mukka
We are deploy a upgrade and we have a doubt
We copy the new ios software to the sup and slavesup. After the reset on the slavesup, it is coming up, we can see the boot process, but the console access stops unexpectedly.
In the Active Sup we can see all status as normal. All working fine. we can´t see the cursor and we can´t the "console inactive messages".
is it a normal behavior in this point of the upgrade process ?
Richard Michael
Have you enabled standby console enable command under the main cpu? If not, enable it and do copy run start and try again.
Richard
