08-15-2024 12:13 AM
Hi.
My company has a mixed stock of 2960X and 9200L switches. We run 24/7 and have a patching window for a few hours once a month. I am in the process of upgrading the IOS on all the switches. I have sent the IOS to all devices and I changed the boot marker on the 2960s so that if there's a power interruption, we get a "free" upgrade. My question is can we do the same with the 9200, so that if it loses power or reboots, it will upgrade the switches to an IOS in flash:
It is just to reduce workload when we have a limited time to carry out our upgrade programme.
Solved! Go to Solution.
08-15-2024 04:03 AM - edited 08-15-2024 04:07 AM
Depends who answers this question.
The official Cisco line is "NO".
Un-officially, yes. Because I do this all the time to our 9500 (9300 uses a different command), ASR 1000, ISR 4000, 9800 WLC.
I would unpack the packages (Install Mode) and set up the "packages.conf" file to point to the new firmware and wait for the power outage to occur. When the switch/router/WLC boots up, "free" firmware upgrade. I must've done several hundreds of "stealth" upgrade and I've never had a switch/router/WLC boot into ROMMON nor boot the wrong firmware.
08-15-2024 12:25 AM
- I would advise against it for both , look for instance at : https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9200/software/release/17-10/release_notes/ol-17-10-9200/upgrading_the_switch_software.html
>...The system reloads automatically after executing the install add file activate commit command (which is a 'current command')
- If you are on 24/7 and or a mission critical networking ; I would not depend on a power loss to complete upgrades , in order
to always follow up on the expected result of an upgrade, (for both platforms)
M.
08-15-2024 12:38 AM
Thanks for the reply. We've now had almost 50 2960s repower and upgrade successfully with no issues, so I'm comfortable with that appliance. I doubt there's a way of doing it with the 9200 but I was asking if there is a way so I can test it in our dev network a few times to see if it's at least feasible
08-15-2024 12:41 AM
- Ok . I think for the 2960s you are rather safe , but for the 9200 I would take more care (indeed)
M.
08-15-2024 12:47 AM
I tend to agree. I'm just trying to "cheat" and save planned outage time by "manipulating" unplanned downtime, if you know what I mean
08-15-2024 12:47 AM
Yes, Agreed with Marce, There will be possibility of unexpected results, which may cause potential impact of services.
Please execute this activity during planned maintenance window.
08-15-2024 01:02 AM
Like I said, I tend to agree. I have your opinions on whether it should be done, but no one has said whether it CAN be done?
08-15-2024 01:09 AM
- In the context of 'can be done' I would for instance suggest to (always) connect a reference console to one of the 9200L , so if it get's upgraded 'with power loss' ; then you have one reference device where you can review how it performed when booting again (e.g.)
M.
08-15-2024 05:04 AM
( I would also like to add ) => Consider it mandatory to have a network monitoring solution in place when considering
the particular workflow : to have an immediate look into availability of all switches
after a power interrupt (or not!). I myself use NAGIOS , it's free but requires manual work
to configure ,there are other free network management tools, for Cisco you have
Catalyst Center , but it is $$.....
M.
08-15-2024 06:12 AM
Yes we have Nagios and also DNA (or whatever it is called this week).
08-15-2024 06:27 AM
- Well there is a big difference between them , NAGIOS is free and Cisco DNA not , but anyway good to have
and of course use after a power interruption , (to watch the network)
M.
08-15-2024 03:41 PM
Please have a look at the attached PDF files. Either one, with some modifications, are applicable to the 9200.
08-16-2024 01:35 AM
Thanks Leo
08-16-2024 01:36 AM
@Leo Laohoo I can't open the attachments
