11-02-2011 11:01 AM - edited 03-07-2019 03:10 AM
Hello All,
I was upgrading one of our Companies Cisco 2801 routers today and I ran into an intresting issue. The image I was loading was:
c2801-adventerprisek9-mz.124-5c.bin, and its requirements were 128MB of RAM and 64 MB Flash. I verified this with a show ver, which returned this:
Cisco 2801 (revision 7.0) with 118784K/12288K bytes of memory.
Processor board ID FTX13088R33
2 FastEthernet interfaces
1 Serial interface
1 Virtual Private Network (VPN) Module
WIC T1-DSU
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
62720K bytes of ATA CompactFlash (Read/Write)
However when I boot I recieve these odd messages:
%SYS-3-IMAGE_TOO_BIG: 'flash:c2801-adventerprisek9-mz.124-5c.bin' is too large for available memory (21820700 bytes).
%SYS-6-READ_BOOTFILE_FAIL: flash:c2801-adventerprisek9-mz.124-5c.bin File read failed -- Not enough space.
%SYS-6-BOOT_MESSAGES: Messages above this line are from the boot loader.
boot of "c2801-adventerprisek9-mz.124-5c.bin" using boot helper "flash:c2801-adventerprisek9-mz.124-5c.bin" failed
error returned: File read failed -- Not enough space
loadprog: error - on file open
boot: cannot load "c2801-adventerprisek9-mz.124-5c.bin"
Then it looks like the router decompresses the image one more time and boots normally. Have you guys even seen anything like this?
Thanks!
11-02-2011 02:35 PM
Can you try a different IOS? The one you're using or upgrading to is pretty ancient.
11-02-2011 03:10 PM
I tried quite a few different IOS images. The one that ended up working with out giving that issue was
c2801-entbasek9-mz.124-5e.bin I think. It was the same revision number just enterprise base instead of advanced enterprise. The reason I have it on such old IOS is because it only have 128MB RAM and 64MB flash. I also need the IP SLA features. Thanks for the help though! If you have any other suggested IOS images that match those feature sets let me know.
