VLAN70 issue
SeshiBhush
Community Member
I have created a Vlan 70. No port is assigned.
It is showing as Vlan70 is up, line protocol is down.
interface Vlan70
ip address 172.16.235.11 255.255.255.0
no ip proxy-arp
NAPRISWI01#sh int Vlan70
  Hardware is EtherSVI, address is 0023.338a.fdca (bia 0023.338a.fdca)
  Internet address is 172.16.235.11/24
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
  Last input 1y31w, output 01:41:02, output hang never
  Last clearing of "show interface" counters 2w1d
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
    0 packets input, 0 bytes, 0 no buffer NAPRISWI01#sh int Vlan70
Ven Taylor
Level 8
Level 8
That's normal.
If you assign vlan70 to a port, or a downstream switch and allow it on the trunk, you'll see up/up.
Think of it as vlan70 is the layer 3 interface (which it is), but there's no "cable" connected (layer2 vlan).
Ven
Ven Taylor
glen.grant
  You created a layer 3 SVI for vlan 70  , you did not create vlan 70 at the layer 2 level .  You need to create the layer 2 vlan for vlan 70 and then put an active device on a port assigned to vlan 70 for the SVI to come up .
