Upgrade IOS Problem for C2960
sam_chang88
There are three 2960 took this problem:
WS-C2960-48TC-S 12.2(25)  2
WS-C2960-24TC-S 12.2(25)  1
upgrade from 12.2(25) to 12.2(50)
upload the IOS by TFTP to flash:
boot system flash:****
wr
reload
Failed to get configuration
Invalid parameter block -- no mac address available.
Xmodem file system is available.
The system has been interrupted, or encountered an error
while non-volatile environment variables were being read
out of flash.  If you interrupted the system, it would be
a good idea to issue the reset command now, or the
environment variables may be lost.  The following
commands will initialize the flash filesystem, and finish
loading the operating system software:
    flash_init
    boot
switch: flash_init
Initializing Flash...
...no flash filesystems found.
than i try to type some command:
switch: dir
List of filesystems currently registered:
xmodem[0]: (read-only)
null[1]: (read-write)
switch: flash_init
switch:
i try to sent original IOS to null: filesystem and successed, but after reboot nothing happen...
is this a hardware problem? just like flash card get crashed....
any suggestion?
thanks and Best REgards
7 Replies 7
Leo Laohoo
Recovery From Corrupt or Missing Software Image on Cisco Catalyst 2900XL and 3500XL Series Switches
http://www.cisco.com/en/US/products/hw/switches/ps607/products_tech_note09186a0080094955.shtml
switch: flash_init
no flash:
HOW to do the next?
I say the 2960, not 2900xl
Type "i", press enter and try again.  Do you get any output when you type "?"?
hi
me to same problem i am using 2960 l2 switch
how can i upgrade
                                                thanks
Parveen,
Are you trying to upgrade your IOS or your current IOS does not load?
only you can do that buy the service of smartnet for the 2960, and change the new one, back the old to factory.
hi
sam there is no ios in ur switch. u have to upload usig xodem in hypererminal.
i did the same it working fine.
regards
praveen kumar gvk.
