Upgrade license from LAN Base to IP Services on WS-C3650-24TD-L
Dinh Viet Thang
Hi everyone,
I have a WS-C3650-24TD-L
Basically, It has Lan Base onboard. Now, I want to run BGP on it, it means that I need to upgrade our license from LAN Base to IP Services.
So what I need to buy more? Only license for IP Services or 2 licenses (1 for IP Base and 1 for IP Services) on this kind of models WS-C3650-24TD-L
Thanks for helping
Seb Rupik
Hi there,
You only need one, the upgrade lisene from LAN Base to IP Services:
L-C3650-24-L-E
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-3650-series-switches/data_sheet-c78-729449.html#wp9001822
cheers,
Seb.
Seb Rupik
Hi there,
L-C3650-24-L-E
cheers,
Seb.
Aha, I saw it.
I just think license policies same as Juniper.
https://www.juniper.net/documentation/en_US/junos/topics/concept/ex-series-software-licenses-overview.html
They wrote:
"Table 4 lists the AFLs that you can purchase for EX3300 switch models. For EX3300 switches, you must purchase and install a corresponding EFL along with the AFL to enable the advanced license features. If you have both these licenses, you can run all of the advanced software features mentioned above on your EX3300 switch"
It means that I need to buy 2 kinds of license to use BGP (EFL + AFL) on Juniper EX3300.
Thanks for your help so much!
