update firmware 3750g
I have a new switch that doesn't have the latest version of firmware.  When I try to add it to my stack it forces the existing switch to re-boot.  Questions
1.  How do I prevent this from hapening?
2.  What is the easiest way to update the firmware on the new switch?  It has no USB ports and I can't seem to get it connected to anything via ip.
5 Replies 5
Reza Sharifi
Before adding it to an existing stack, you need to install the same exact IOS as the rest of the stack.
To install the ios, log to the switch via console, select port and put it in a vlan, create an SVI for that vlan with an IP, connect your laptop to that port and give it an IP in the same segment as the SVI on the switch. Use a TFTP server to transfer the IOS to the switch.
I downloaded the Solarwinds tftp server but can't seem to get the syntax correct from my cisco ASA to my laptop.
my laptop is jdavila.pop.e-mds.com and my asa is XXX  can you provide the correct sequence and command for doing this?  Thanks so much
Juan
cisco ASA?
I thought you want to upgrade a 3750 switch.
I am still unable to update the firmware. Can you please point me to a detailed procedure?
I have downloaded winSCP to get the firmware file from the existing good switch to my laptop and then copy it to the down switch. I have configured an interface on the down switch and can ssh to it.
balaji.bandi
After upgrading the IOS as same as running.
Make sure you setup priority of the Switch - which one you like to master always, If not due to power loss, the Stack election process take effective.
BB
BB
