upgrade of end of sales switches (C3560G and C3650)
william_S
Hello
1- I have  WS-C3560G-24TS switch i want to upgrade from IOS 15.0(2)SE7 to IOS  15.2(7)E2.
Will it work for  WS-C3560G-24TS , since theses switches a no more supported ?
2- I want also to upgrade C3650-24TS from IOS-XE 16.3.5b to IOS-XE 16.11.2
and  C3650-24TS from IOS-XE 03.06.06E to IOS-XE 3.8.10E
 How to do it for C3650-24TS since the target firmware is not available ?
Thank you.
Leo Laohoo
@william_S wrote:
Hello
15.2(7)E2?  Not going to work.  That particular version is for a 2960X/L and compact switches only.
Did anyone read the Release Notes for 16.11.2?  There is no 16.10.X nor 16.10.X release for 3650/3850?
Not going to work.  There is no 3.8.X release for 3650/3850.
thank you @leo
The update is linked to the advisory of 3rd june 2020.So could Cisco do Something for this or should i throw away my switches
If the switch is at end-of-support, Cisco will not update the software. So, either you'll need newer switches or live with "flaw" that exists.
Read the Security Bulletin very carefully.
Not all vulnerabilities apply to the switches you own.
