FRU Control Configuration Module Not Ok
Vic48
Level 2
Level 2
Had an issue like this before and it was stack member related, but this time the only issue is a module light coming up as amber. It doesn't appear to be hardware related, but I'm not sure.
License Information for 'WS-X45-SUP7L-E'
License Level: ipbase Type: Permanent
Next reboot license Level: ipbase
cisco WS-C4507R+E (MPC8572) processor (revision 6) with 2097152K bytes of physical memory.
Processor board ID FXS1822Q0YV
MPC8572 CPU at 1.5GHz, Supervisor 7L-E
Last reset from PowerUp
2 Virtual Ethernet interfaces
200 Gigabit Ethernet interfaces
4 Ten Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
MatawanVoice_4507-1#show env
no temperature alarms
Module Sensor Temperature Status
1 Air inlet 31C (56C,68C,71C) ok
1 Air inlet remote 22C (46C,59C,62C) ok
1 Air outlet 32C (66C,76C,79C) ok
1 Air outlet remote 27C (60C,71C,74C) ok
2 Air inlet 30C (56C,68C,71C) ok
2 Air inlet remote 22C (46C,59C,62C) ok
2 Air outlet 32C (66C,76C,79C) ok
2 Air outlet remote 26C (60C,71C,74C) ok
3 XPP 32C (52C,64C,67C) ok
3 XPP Remote 40C (61C,75C,78C) ok
3 IFE 29C (56C,68C,71C) ok
3 IFE Remote 34C (61C,74C,77C) ok
3 CPU 27C (47C,61C,64C) ok
3 CPU Remote 34C (61C,77C,80C) ok
4 XPP 29C (52C,64C,67C) ok
4 XPP Remote 33C (61C,75C,78C) ok
4 IFE 27C (56C,68C,71C) ok
4 IFE Remote 29C (61C,74C,77C) ok
4 CPU 25C (47C,61C,64C) ok
4 CPU Remote 36C (61C,77C,80C) ok
5 Air inlet 30C (56C,68C,71C) ok
5 Air inlet remote 22C (46C,59C,62C) ok
5 Air outlet 29C (66C,76C,79C) ok
5 Air outlet remote 24C (60C,71C,74C) ok
6 Air inlet 29C (56C,68C,71C) ok
6 Air inlet remote 21C (46C,59C,62C) ok
6 Air outlet 30C (66C,76C,79C) ok
6 Air outlet remote 25C (60C,71C,74C) ok
Power Fan Inline
Supply Model No Type Status Sensor Status
PS1 PWR-C45-4200ACV AC 4200W good good good
PS1-1 220V good
PS1-2 220V good
PS2 PWR-C45-4200ACV AC 4200W good good good
PS2-1 220V good
PS2-2 220V good
Power supplies needed by system : 1
Power supplies currently available : 2
Chassis Type : WS-C4507R+E
Power consumed by backplane : 40 Watts
Switch Bandwidth Utilization : 0%
Supervisor Led Color : Green
Module 1 Status Led Color : Green PoE Led Color : Green
Module 2 Status Led Color : Green PoE Led Color : Green
Module 3 Status Led Color : Green
Module 4 Status Led Color : Orange
Module 5 Status Led Color : Green PoE Led Color : Green
Module 6 Status Led Color : Green PoE Led Color : Green
Fantray : Good
Fantray removal timeout : 138
Power consumed by Fantray : 165 Watts
MatawanVoice_4507-1#show module
Mod Ports Card Type Model Serial No.
1 48 10/100/1000BaseT Premium POE E Series WS-X4748-RJ45V+E CAT1831LA24
2 48 10/100/1000BaseT Premium POE E Series WS-X4748-RJ45V+E CAT1831L96R
3 6 Sup 7L-E 10GE (SFP+), 1000BaseX (SFP) WS-X45-SUP7L-E CAT1832L1WZ
4 Supervisor
5 48 10/100/1000BaseT Premium POE E Series WS-X4748-RJ45V+E CAT1833L0TL
6 48 10/100/1000BaseT Premium POE E Series WS-X4748-RJ45V+E CAT1833L0TQ
M MAC addresses Hw Fw Sw Status
1 f07f.064c.d1b0 to f07f.064c.d1df 1.5 Ok
2 f07f.064c.c6d0 to f07f.064c.c6ff 1.5 Ok
3 f40f.1b5a.aa40 to f40f.1b5a.aa45 3.0 15.0(1r)SG10 03.07.03.E Ok
4 Unknown Unknown Unknown Other
5 f07f.0673.7030 to f07f.0673.705f 1.5 Ok
6 f07f.0673.6f40 to f07f.0673.6f6f 1.5 Ok
Mod Redundancy role Operating mode Redundancy status
3 Active Supervisor SSO Active
4 Standby Supervisor SSO Disabled
Anyone know what the significance of Module 4 Status Led Color : Orange is?
Thanks!
Reza Sharifi
Is the second sup (module 4) exactly the same as the primary sup? Does it have the same exact IOS installed? Can the sup be reinserted into the chassis?
Reza Sharifi
Thanks for your assistance with this issue, but since it's not service impacting we decided to leave things as is.
