Upgrade Power Supply on Cat 6506 form 3000W to 6000W
Stefan Sawluk
Hello Folks.
I have to upgrade my power supplys in my cat 6506-E Switches from 3000W to 6000W. The 3000W PS are in redundancy mode. When i now change one 3000W to a 6000W do i have there downtime?
Regards Stefan
Rajeev Sharma
Hey Stefan,
I suggest changing the power redundancy to combined before replacing the PS units. As in redundancy mode when chassis detects different wattage power supplies it error-disables the lower wattage PS unit. So it should be like this:
1. Change the power redundancy mode to combined
2. Replace the PS units
3. When both the PS slots will have 6000W power supplies, configure the power redundancy mode to redundant again.
HTH.
RS.
8 Replies 8
Rajeev Sharma
Hey Stefan,
HTH.
RS.
Hello Rajeevsh.
Thank you for your replay. I have read this, that the lower PS will disabled when i plug in a higher wattage PS. But its good to know that i have to change the mode. When i change this i don´t have downtime?
Regards Stefan
Hey Stefan,
With this method there will be no downtime :)
RS.
Hey Guys.
Everything worked great. I had no downtime.
Stefan
Happy to help :)
RS.
Hello Stefan, i want to know if you already change the PS.
Did you have any downtime with this procedure?
Hi. No, I think i will test this next week.
Regards Stefan
Ok, i would appreciate if you let me know the results.
