Upgrade two cisco Nexus 5672UP
We want to make an software upgrade from version 7.2 (0) N1 (1) to 7.3 (3) N1.
Can you please help me for a Action Plan and confirm to me if it is possible to make the ISSU upgrade.
N5k2# sh version
Cisco Nexus Operating System (NX-OS) Software
TAC support: http://www.cisco.com/tac
Documents: http://www.cisco.com/en/US/products/ps9372/tsd_products_support_series_home.html
Copyright (c) 2002-2015, Cisco Systems, Inc. All rights reserved.
The copyrights to certain works contained herein are owned by
other third parties and are used and distributed under license.
Some parts of this software are covered under the GNU Public
License. A copy of the license is available at
http://www.gnu.org/licenses/gpl.html.
Software
  BIOS:      version 2.1.2
  Power Sequencer Firmware:
             Module 1: v4.0
             Module 1: v4.0
  Fabric Power Sequencer Firmware: Module 1: version v4.0
  Microcontroller Firmware:        version v0.0.0.15
  QSFP Microcontroller Firmware:
             Module 1: v2.0.0.0
  CXP Microcontroller Firmware:
             Module not detected
  kickstart: version 7.2(0)N1(1)
  system:    version 7.2(0)N1(1)
  BIOS compile time:       07/16/2014
  kickstart image file is: bootflash:///n6000-uk9-kickstart.7.2.0.N1.1.bin
  kickstart compile time:  6/8/2015 0:00:00 [06/08/2015 10:36:48]
  system image file is:    bootflash:///n6000-uk9.7.2.0.N1.1.bin
  system compile time:     6/8/2015 0:00:00 [06/08/2015 10:37:40]
Hardware
  cisco Nexus 5672UP Chassis ("Nexus 5672UP Supervisor")
  Intel(R) Xeon(R) CPU  @ 1.80 with 8243344 kB of memory.
  Processor Board ID FOC20040CXZ
  Device name:
  bootflash:    7692288 kB
Kernel uptime is 783 day(s), 1 hour(s), 53 minute(s), 25 second(s)
Last reset
  Reason: Unknown
  System version: 7.2(0)N1(1)
  Service:
plugin
  Core Plugin, Ethernet Plugin
N5k2#
Best Regards,
balaji.bandi
2 5K are in vPC ? how is your setup.
Look at the upgrade procedure and upgrade matrix in the below link, follow same steps all works as expected.
make sure you do this in change window, in case they are standalone.
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus5600/sw/upgrade/731_N1_1/n5600_upgrade_downgrade_731_n1_1.html
BB
BB
