Upgrading Cisco Catalyst 4500 series Supervisor question
firestormnet
Hi All.
Does anybody know if a new Cisco Catalyst 4500 series supervisor 7L-E model WS-X45-SUP7L-E is backward compatible with a Cisco Catalyst 4500 series chassis model 4507R?
I've checked on Cisco website for that Supervisor and it shows only new chassis models WS-C4507R+E and R-E, but what about old type of chassis? We need to upgrade that Supervisor as it's out of line, but we don't really want to buy a new chassis as well as it's going to be very pricy.
Thanks for your support.
3 Accepted Solutions
rsimoni
the info is on the same link I posted few minutes ago on another thread.
"This engine is supported on E-series, R-E, and R+E chassis." So you need a E type of chassis. 4507R is not good.
from Release Note for Catalyst 4500 Series Switch, Release IOS-XE 3.2.x SG"
http://www.cisco.com/en/US/partner/docs/switches/lan/catalyst4500/release/note/OL_24726.html#wp2482302
please rate and close question if helpful.
regards,
Riccardo
lvchichevron
Based the info from Cisco website at http://www.cisco.com/en/US/products/hw/switches/ps4324/prod_models_comparison.html#4500, apparently, sup 7LE is not compatibale with 4500 classic chassis.
to see the link I gave you, you need to be registered on Cisco.com (CCO) site; basic registration allows you to see docs.
About your question, table 3 of 'Release Notes for the Catalyst 4500 Series Switch, Cisco IOS Releases 12.2(54)SG to 12.2(37)SG' gives you the answer
http://www.cisco.com/en/US/partner/docs/switches/lan/catalyst4500/release/note/OL_5184.html
Catalyst 4507R supports:
Supports Supervisor Engine 6L-E, Supervisor Engine 6-E,
Supervisor Engine V-10GE, Supervisor Engine V,
Supervisor Engine IV, Supervisor Engine II-Plus-10GE, and
Riccardo
6 Replies 6
rsimoni
regards,
Riccardo
lvchichevron
Thanks for your answers lads.
Riccardo, your link doesn't work, says Forbidden File or Application.
Guys, do you know to what model of Catalyst 4500 supervisor should I upgrade then? without changing the Catalyst 4507R chassis?
Existing supervisor is out of line and production, so i suppose we won't get a support and service on that Supervisor.
Will Supervisor Engine 6-E, 6L-E,  V-10GE, V, IV,  II-Plus-10GE, II-Plus would support 4507R chassis?
Thanks.
Riccardo
Thanks a lot for your answers, appretiate that.
All the best.
my pleasure.
would you mind flagging the question as answered please?
Riccardo
