clear df bit + policy based routing
raf.vanderveken
I've been implementing a setup where a remote office has a cisco 1900 router.
There are 2 GRE/IPSEC tunnels to the headquarters, 1 over public internet, 1 over a private cloud.
Because of some MTU issues we have te clear the DF bit for some of the traffic, but
we also want to use PBR to send https traffic over the "public internet" tunnel and the rest of the traffic
over the "private cloud" tunnel. I'm able to clear the DF bit and to do the PBR with route-maps, but
I'm not able to implement both functionalities at the same time.
Does someone has an idea how to solve this issue ?
thanks
raf
lgijssel
Level 9
Level 9
It is possible to have multiple set-commands with the same match-command.
Could look like this:
route map-entry 10
match https traffic
set df-clear
set ip next-hop
route map-entry 20
match all other traffic
set df-clear
set ip next-hop (if applicable)
The above syntax is obviously not correct but if you grasp the idea, you might be able to make it work.
Looks like finding the correct syntax is not your problem.
If this does not do the trick, you should provide the config.
regards,
Leo
