Upgrading Switch 3750 Switch
tinchan2010
Community Member
Hi All,
Can anyone help me to give me the version for upgrade, i need to use SSH instead of telnet, which version could i upgrade to?
#show version
Cisco IOS Software, C3750 Software (C3750-IPSERVICES-M), Version 12.2(50)SE5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Tue 28-Sep-10 12:56 by prod_rel_team
Image text-base: 0x01000000, data-base: 0x02C00000
ROM: Bootstrap program is C3750 boot loader
BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M) Version 12.2(44)SE5, RELEASE SOFTWARE (fc1)
ExtL3SW_C3750G_02 uptime is 41 weeks, 1 day, 1 hour, 44 minutes
System restarted at 09:59:30 SGT Sun Dec 23 2012
System image file is "flash:/c3750-ipservices-mz.122-50.SE5/c3750-ipservices-mz.122-50.SE5.bin"
cisco WS-C3750G-24TS (PowerPC405) processor (revision S0) with 131072K bytes of memory.
Processor board ID CAT0933Z1M5
Last reset from power-on
4 Virtual Ethernet interfaces
28 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 00:15:2B:B5:86:00
Motherboard assembly number     : 73-7058-16
Power supply part number        : 341-0045-02
Motherboard serial number       : CAT09330J2H
Power supply serial number      : LIT15071162
Model revision number           : S0
Motherboard revision number     : A0
Model number                    : WS-C3750G-24TS-E
System serial number            : CAT0933Z1M5
Top Assembly Part Number        : 800-22348-09
Top Assembly Revision Number    : A0
Version ID                      : V09
CLEI Code Number                : CMMAK00ARA
Hardware Board Revision Number  : 0x09
Switch Ports Model              SW Version            SW Image
*    1 28    WS-C3750G-24TS     12.2(50)SE5           C3750-IPSERVICES-M
Configuration register is 0xF
Sandeep Choudhary
Hi Rohayu,
The IOS (c3750-ipservices-mz.122-50.SE5.bin) being used does not  support any encryption, thats why you are not able to configure ssh on  vty lines
You need to upgrade the IOS with a featureset which has k9 in it, for eg.:
c3750-ipservicesk9-mz.122-35.SE5.bin
c3750-advipservicesk9-mz.122-35.SE5.bin
Reagrds
