Upgrading the CEF720 Module ROMMON
hotshin03
Hi all
In the following step
Step 2 working at service downtime occur?
To upgrade the ROMMON version on your CEF720 module, perform these steps
Step 1
Check the active ROMMON information:
Router# show rom-monitor slot 4
Region F1:APPROVED, preferred
Region F2:INVALID
Currently running ROMMON from F1 region
Router#
The display indicates that the active ROMMON is running in region1.
Step 2
Program the new ROMMON image to the Flash device on the module (in this example, the image is
stored in the route processor bootflash):
Router# upgrade rom-monitor slot 4 file bootflash:c2lc-rm2.srec.122-18r.S1
Copying bootflash:c2lc-rm2.srec.122-18r.S1 onto bootflash of dfc#4 CCCCCCCCC
CCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCC
Router#
19:40:08: DFC4: ROMMON image upgrade in progress
19:40:08: DFC4: Erasing flash
19:40:11: DFC4: Programming flash
19:40:13: DFC4: Verifying new image
19:40:13: DFC4: ROMMON image upgrade complete
The card must be reset for this to take effect
Step 3
Check the new active ROMMON information:
Region F1:APPROVED
Region F2:FIRST_RUN, preferred
Router#
Step 4
Reload the module for the change to take effect:
Router# hw-module module 4 reset
Proceed with reload of module? [confirm]
% reset issued for module 4
<output truncated>
Step 5 After the system comes up, check the ROMMON information again:
Region F1:APPROVED
Region F2:APPROVED, preferred
Currently running ROMMON from F2 region
Router#
Reza Sharifi
Yes, this will cause on outage since you have to reset the module after the upgrade.
Joseph W. Doherty
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
Upgrading a sup's ROM can be done while the sup is active.  Actually having the sup use the new code will require rebooting the sup.  If you have dual sups, you can do this failing from one sup to the other.  (If you're doing both sups, don't forget to insure 1st sup being reloaded comes fully back on-line before doing 2nd.)  If you have a single sup, it will cause a hit to the whole chassis.
