Uplinks on Switch Stack, Design question
neteng2323
I need advice on where to place uplinks on switch stack, and which switch should be secondary master.  For example, I have a stack of 5 switches (1-5 racked vertically) my first switch is set as the master, second switch is set to take over for the master.  Does it matter where I place the uplinks?  My plan is to have 3 stacks like this in a closet, and 2 uplinks back to a distribution switch on each stack.  I would give the Master the first uplink, and maybe the 3rd switch the second uplink.... Should I make a different switch the secondary other than the second switch?
EDIT:  The Switch stack model:  2960-X
11 Replies 11
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
What switch model series are you asking about?
On the 3750 series, Cisco recommends stack master not host uplinks, but personally I think it makes little difference.
Sorry, I should have specified that... They are 2960-Xs.
All members of stacks send controls messages to the stack masters and stack master sends control messages such as STP out; however, traffic will be sent out by all members.
If the other side is only one switch, it does not matter where to put uplink, but if you are using  technologies such VSS or VPC which several switches can be acted as a single switch, master should be connected to master since master members pass control messages to master.
If the switches on other sides are also stack, then master should be connected to master to avoid control messages pass over stack cable.
You can connect them randomly and it works because control traffic is not comparable to data traffic. If you are very concern about the best performance, then connecting master to master is suggested.
Hope it helps,
Masoud
I'm not sure I'm following, I will have 2 uplinks per stack that connect back to  a Nexus distro switch in a VPC configuration.
I am sorry. I misunderstood your question. If you have five stack members, you should have 10 uplinks to VPC.
I hope I understood your question this time.
Masoud
The otherside of the uplinks will be a VPC configuration on the Nexus distribution switch.  The stacks of 2960s will have a port channel between the 2 uplinks.  5 uplinks would mean I would need 15 sfp's on the Nexus?  Thats gonna be expensive.
How did you calculate 15? If you have 5 stack switches, each switch should be connected to VPC by two uplinks. If you have 2 VPC members, you need 10 uplinks totally.
Masoud
Ok, gotcha.. I misunderstood this time.  I thought you were saying each switch in the stack is getting an uplink.  I will have 2 uplinks per stack, for a total of 6 physical connections (3 VPCs) back to the Nexus.
If you use stack member instead of stack, it will be more clear. 2 uplinks per stack means to me that if you have 5 stack members you only have 2 uplinks for all 5.
If you have 5 switches are stack together, you will have 2 uplinks for eack stack member and 10 total uplinks for stack(or per stack).
Are we on the same page :)?
Masoud
Yes, 2 uplinks for all 5.  So, anything more than that is just for redundancy correct?  The stack ring speed is only 20G... What are the other benefits of having 1 link per stack member?
Since ether channel is used to connect stack members to VPC, having more uplinks, gives you more bandwidth. In my opinion,2 uplinks, for 5 switch is not enough. Full mesh is suggest, but if achieving full mesh is difficult, use at least 4 links to create cross topology. One of the links from active switch. Give more stack priority to other switches which have uplink to VPC.
Connect master switch to VPC master.
Hope it helps,
Masoud
