UPnP in Cisco switched infrastructure
Thorsten997
There are UPnP servers and UPnP clients in the network. Servers are connected to Cat6509, clients are connected to Cat3560 and there is connectivity between these switches. At the moment there is no UPnP connectivity between clients and servers. What is needed to do on switches to support UPnP?
Florin Barhala
Level 6
Level 6
UPnP runs at Layer 4 or above; all you need is full Layer 2 connectivity (allow same vlan span from servers to clients), then at layer 3 clients need IP addresses from servers so you have to configure DHCP relay on the right interface.
