URGENT 3750 Stack - %PHY-4-SFP_PLUS_NOT_SUPPORTED
jperezam
I keep getting this error eventhough it seems I have everything CISCO requires on my 3750 switches STACK to operate the CVR-X2-SFP10G module
here is my output:
My Inventory on the modules:
NAME: "Switch 1 - Slot 1 - TenGig Converter Module", DESCR: "TenGig Converter Module"
PID: CVR-X2-SFP10G     , VID: V02  , SN: FOC150110HF
NAME: "TenGigabitEthernet1/0/1", DESCR: "unknown"
PID: SFP-H10GB-CU3M      , VID: ^A    , SN: MOC14500724
IOS Version:
Version 12.2(55)SE1
c3750e-universalk9-mz.122-55.SE1.bin
According to the following link, I can use this module and cable with my 3750 but still not wroking and the ERROR message in my log keeps appearing.
http://www.cisco.com/en/US/prod/collateral/modules/ps5455/data_sheet_c78-547521.html
I need to raise an EQUALOGIC Storage area ASAP and cant get connectivity on this modules
I'll really appreciate Help on this matter.
5 Replies 5
Collin Clark
Sorry, it seems not everything was posted, here is the detail:
here is my output:
IOS Version:
Version 12.2(55)SE1
Assuming you have one of these platforms;
WS-C3750E-24TD
WS-C3750E-24PD
WS-C3750E-48TD
WS-C3750E-48PD
WS-C3750E-48PDF
it should work. I would open a TAC case as it looks like you have supported hardware and are above the miminum level of IOS.
correct, this is what I have
WS-C3750E-48TD-S
I opened a TAC case now, and waiting for the faster response :S
RMA the SFP-H10GB-CU3M.  I'm suspecting you have the old version 1.  Only Version 2 of the SFP-H10GB-CU3M are supported.
http://www.cisco.com/en/US/customer/docs/interfaces_modules/transceiver_modules/compatibility/matrix/OL_6974.html
