URGENT QUESTION
mmtantawi
Dear All,
i have the following question regarding the NAT Configuration.
as Every One Knows we have in NAT Terminology the following Terms :-
1- Inside Local Address, which is Private Network or which is MY LAN IP Address .
2- Inside Global Address, which is the legitimate IP Address assigned by the NIC Or the ISP Provider, which is the Real IP Address.
now, the 2 terms which i mention is used only in STATIC ,Dynamic , Overloading NAT.
Now, My question is :-
1- if i have this real IP Address assigned by my ISP, 64.202.88.20 , and i have an Internal WEB SERVER inside My Company and the WEB SITE is on it.
i want to make NAT to let all the People from out side access this Server through NAT it self by http. how can i wrote the IP NAT COMMAND ?
which one is the OUTSIDE LOCAL ADDRESS & which one is the OUTSIDE GLOBAL ADDRESS ?
Please Reply .
farkascsgy
Level 4
Level 4
ip nat inside source static "Inside local" "inside global"
ip nat inside source static "Private address" 64.202.88.20
Don't forget permit the http traffic in ACL, what is applied to the outside interface, if you don't have the best is you cerate one and just permit traffic what is really need...
Brifly:
Outside local - the other end private address
Outside global - the other peer global address
bye
FCS
Please rate me if I helped.
