10-23-2008 08:51 AM - edited 03-06-2019 02:06 AM
I need some help and clarification on this issue. I am in the process of upgrading the IOS on a
Switch from Upgrading of the IOS from c6sup22-psv-mz.121-19.E1a.bin to 12.2(18)SXD7b c6k222-ps-mz.12.2-18.SXD7b.
The show version gives the following
ROM: System Bootstrap, Version 12.1(11r)E1, RELEASE SOFTWARE (fc1)
BOOTLDR: c6sup2_rp Software (c6sup2_rp-PSV-M), Version 12.1(19)E1a, EARLY DEPLOYMENT RELEASE SOFTWARE (fc2)
uptime is 4 days, 13 hours, 18 minutes
Time since switched to active is 4 days, 13 hours, 12 minutes
System returned to ROM by power-on (SP by power-on)
System restarted at 02:59:58 BST Sun Oct 19 2008
System image file is "sup-bootflash:c6sup22-psv-mz.121-19.E1a.bin"
cisco WS-C6509 (R7000) processor (revision 3.0) with 112640K/18432K bytes of memory.
Processor board ID SAL0720D9PF
R7000 CPU at 300Mhz, Implementation 39, Rev 3.3, 256KB L2, 1024KB L3 Cache
Last reset from power-on
X.25 software, Version 3.0.0.
Bridging software.
1 Virtual Ethernet/IEEE 802.3 interface(s)
288 FastEthernet/IEEE 802.3 interface(s)
4 Gigabit Ethernet/IEEE 802.3 interface(s)
381K bytes of non-volatile configuration memory.
32768K bytes of Flash internal SIMM (Sector size 512K).
Standby is up
Standby has 112640K/18432K bytes of memory.
Is this enough for the upgrade?
The Cisco Websites says I need the following for the upgrade
IP
c6k222-psv-mz.122-18.SXD7b.bin
Release Date: 12/Dec/2006
IP
Size: 37385.21 KB (38282452 bytes)
Minimum Memory: DRAM:256 MB Flash:64 MB
Do I have enough DRAM and if I dont what do I need?
10-23-2008 09:12 AM
Hi, you do no have the DRAM required, you currently have 128 Megs shown in the show version output of 112640K/18432K bytes of memory
You need 256 DRAM
here is memory tables for various platforms
http://www.cisco.com/en/US/products/hw/switches/ps663/products_tech_note09186a00801a5d58.shtml
Rgds
Jorge
10-24-2008 12:02 AM
So which one do I purchase
MEM-MSFC2-512M or MEM-S2-512M.
We have a Supervisor 2 / MSFC 2 card running native IOS.
If I do a remote switch command on the same show version I get the folloiwng
remote command switch show vers
IOS (tm) c6sup2_sp Software (c6sup2_sp-SPV-M), Version 12.1(19)E1a, EARLY DEPLOYMENT RELEASE SOFTWARE (fc2)
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Wed 06-Aug-03 06:36 by hqluong
Image text-base: 0x40020C00, data-base: 0x4095E000
ROM: System Bootstrap, Version 7.1(1)
BOOTLDR: c6sup2_sp Software (c6sup2_sp-SPV-M), Version 12.1(19)E1a, EARLY DEPLOYMENT RELEASE SOFTWARE (fc2)
uptime is 4 days, 13 hours, 17 minutes
Time since switched to active is 4 days, 13 hours, 11 minutes
System restarted at 02:59:18 BST Sun Oct 19 2008
System image file is "bootflash:c6sup22-psv-mz.121-19.E1a.bin"
cisco WS-C6509 (R7000) processor (revision 3.0) with 458752K/65536K bytes of memory.
R7000 CPU at 250Mhz, Implementation 39, Rev 2.1, 256KB L2, 1024KB L3 Cache
So which do I need or do I have enough.
THanks
10-24-2008 12:56 AM
MEM-S2-512M
10-24-2008 02:49 AM
Thank you. I got this email from Cisco.
..........It looks to me like you were trying to install sup memory instead of MSFC memory. MEM-S2-512MB is memory for the supervisor and MEM-MSFC2-512MB= is the memory for the MSFC. They aren't interchangeable. Here's a link regarding the MSFC memory installation.
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/hardware/Config_Notes/78_6953.html
But, if you have MEM-S2-512MB and not MEM-MSFC2-512MB=, you won't be able to upgrade to get the new IOS installed. ............
What does this mean, as this is now confusing.
My thots were that all I need was MEM-S"-512M but when this was written to me from Cisco, it kind of confused me.
Please help.
10-24-2008 06:07 AM
You need the MSFC memory upgrade (MEM-MSFC2-512MB=) because you are running the switch in native mode, not hybrid (switch + router).
In native mode the "switch" is running IOS from the MSFC.
In hybrid mode the sup runs CatOS and the MSFC IOS.
Hope this helps
