USB Drivers for ISR 4321
Nehru Becirovic
We recently purchased this router and it does not have RJ45 serial port but only USB mini.  For the life of my I can't get it to work.  I tried Windows update, USB drivers for 2911 (because I can't find any other ones) but still not working.
Has anyone else had success using USB with similar router to get console access?
acampbell
According to the installation manual there is both a USB-Mini & RJ45 console
http://www.cisco.com/c/en/us/td/docs/routers/access/4400/hardware/installation/guide4400-4300/C4400_isr/Overview.html#99991
Figure 1-17 Back Panel Ports on the Cisco ISR4321
Grounding
Power switch
Power input connector
GE “MGMT” port (with USB port below)
USB Type B mini port
6
Console port
7
Auxiliary port
8
GE 0/0/1 (copper cable) port
9
GE 0/0/0 RJ-45 (copper cable) port
GE 0/0/0 SFP (fiber-optic) port
Regards, Alex. Please rate useful posts.
acampbell
Grounding
Power switch
6
Console port
7
Auxiliary port
8
9
