USB not recognised
robertkwild
hi all,
getting this error when i insert a USB flash drive in a cisco switch
dir usb1:
usb is either not present or not formatted or not mounted
ive tried FAT and FAT32, only tried one make tho
thanks,
rob
aleabrahao
Meraki Community All-Star
What is the brand and capacity of the flash drive? I've seen cases where drives larger than 32GB don't work.
In other instances, only Kingston models worked.
Try using a different flash drive.
I am not a Cisco employee. My suggestions are based on documentation of Cisco, best practices and day-to-day experience.
Please, if this post was useful, leave your kudos and mark it as solved.
As @aleabrahao correctly notes, Cisco devices can be sensitive to USB flash size and/or brand (they usually work fine with Cisco flash sticks).
Another issue you can run into, especially with much older Cisco devices, their ROMMON code may need updating.
Hi @robertkwild ,
what model of switch and what IOS are you using. Older models of switches have tighter restrictions. Newer switches like the Catalyst 9200/9300 running IOS XE can cope with much larger USB capacities like 32 or 64 GB.
Hope this helps.
Regards, LG
*** Please Rate All Helpful Responses ***
