USB not recognized in 3850
Hi all,
Im trying to transfer a IOS image to upgrade a 3850 switch, as soon as I put the USB drive to the front of the switch, I go to the CLI and run the command: show usb-devices summary (it is the only command available) and it shows and display the name and even the serial of the USB,
however, if I want to see the files (IOS image file) inside the USB, with the command show usbflash0:/ it does not show anything,
I tried to search for answer on the forum but no like this one, and a lot of post states that with the command: dir usbflash0:/ will display but this command is not available,
is there a command to active a usbflash0:/ slot ?
I even tried formatting the drive to FAT32 and NTFS but still the same results,
Am I missing something?
the current switch IOS image is:
Cisco IOS Software [Denali], Catalyst L3 Switch Software (CAT3K_CAA-UNIVERSALK9-M), Version 16.3.1, RELEASE SOFTWARE (fc3)
Switch Ports Model              SW Version        SW Image              Mode
*    1 32    WS-C3850-24S       16.3.1            CAT3K_CAA-UNIVERSALK9 INSTALL
19 Replies 19
And for MAC:
diskutil list
diskutil eraseDisk FAT32 EMPTY MBRFormat /dev/diskN
diskutil partitionDisk /dev/diskN MBR FAT32 "Primary" 4000M FAT32 "Second" R
syed.faridi
I had the same issue with 4500-X, USB file when connected to the switch would become 0 in size. Reformatting my USB with fat32 worked, solution provided in this forum is correct.
Ali.Raeesi
You can easily use USB 2.0 flash and Fat32 format .
new version of routers used USB 3.0 today I have installed cisco C1117
TyIT
I ran into this same issue before, I tried a different USB and it worked just fine.
