Use of Spanning-tree extend system-id for vlan verification
I understand that the system-id extension is used to create a unique BID per vlan in PVST+. My question is
1) Does the receiving switch will use that "System-id extension" field to verify the vlan that the frame is received?
2) What if there is a native vlan mismatch between the switches( One side is Vlan 100 and the other side is vlan 200). Does the switch use that system-id extension to figure out the issue?
2 Accepted Solutions
ammahend
No, its only used to identity the correct VLAN for the BPDU
No, I don't think so. usually its CDP and LLDP which identifies native vlan mismatch.
-hope this helps-
Martin L
system-id extension is included in Bridge ID part of BPDU section which included in main STP (Cisco and IEEE versions) frame.  In case native vlan mismatch, I think STP will show u message and put ports in disable mode. This may be based on CDP frame that carries native vlan id I think (not 100% sure so need to check it out)
Regards, ML
**Please Rate All Helpful Responses **
7 Replies 7
ammahend
-hope this helps-
Got it. Thanks for clarifying!
Martin L
Regards, ML
Here is Wireshark STP capture; notice vlan ID "in red" ; Filed indicating vlan id is inside of TLV (6 bit towards end) part of STP frame from my picture in previous post
Regards, ML
That makes sense. Thank you so much for confirming!
Thanks for the including the picture!
