Use Usable IP Range in cisco router
osaid suliebi
Dear All,
I have cisco router 881 (4 LAN ports) and 1 WAN port, i setup internet connection by assign IP fom ISP to WAN port (/30), also i have 4 usable IP range , HOW can i use these 4 ips to devices (i need use one ip to device and second IP to another device and so on..
assign e.g. 213.6.82.33/29 to the LAN interface of your router, and then you can use any of the other addresses (34 thru 38) for your devices.
12 Replies 12
what are the IP addresses given to you ? I am just asking because the /30 usually implies only one useable IP address on your side.
Either way, you can either use static NAT or, if the (public) IP addresses need to be directly assigned to your end devices, use a bridge group.
Hello
You can use Network Translation to map the public IP addressing to individual inside hosts when applicable.
or
You can bridge the rtr to colapse the wan subnet into your lan network?
(I would suggest the first option would be more applicable?
Be happy to provide examples if required?
res
Paul
Kind Regards
Paul
Thanks  for your replay, i think i need also define ip pool for my range (4 IPs) in addition to Static NAT, correct? and are there addition config??
which (block of) IP addresses did you get ?
Post the config of your router, and we can add the necessary bits and pieces...
IP block : 213.6.82.34-38 / 255.255.255.248.
Another Question: Can i connect my device to LAN port in router and Assign to this device IP from range that i have??
If Yes, kindly post to me example, i will post my conf..
what is the IP address and mask assigned to the WAN interface ? Is that an address from that same range ?
Usable addresses are 33- 38, by the way.
WAN IP is 213.6.78.186 /255.255.255.252
Just i want to connect my device (DVR) to one of router LAN port and access directly to this device by using one of ip from range..
Thanks Geroge,
Assigne 213.6.82.33/29 as gateway to device that connect to any LAN port of router??
in another word: Assigne 213.6.82.33/29 to VLAN1?(as you know vlan1 contains the 4 LAN ports of router)
Thanks Again for your help..
Exactly. 213.6.82.33/29 to VLAN1.
Thanks you Dear,
Please note i configured IP pool as below, is this needed and nessesary??
ip nat pool Paltel_Range 213.6.82.37 213.6.82.37 netmask 255.255.255.248
ip nat pool Paltel_Range_37 213.6.82.37 213.6.82.37 netmask 255.255.255.248
ip nat pool Paltel_Range_36 213.6.82.36 213.6.82.36 netmask 255.255.255.248
ip nat pool Paltel_Range_35 213.6.82.35 213.6.82.35 netmask 255.255.255.248
ip nat pool Paltel_Range_34 213.6.82.34 213.6.82.34 netmask 255.255.255.248
you don't need these pools at all, since you are using public IP addresses. That said, do you have any other hosts in your network with private IP addresses ? If that is the case, you would need to NAT those, but not using a pool, but just an overload to the WAN interface...
