username in 9000 switch
Mbezayiff1
I have a 9000 switch and when I try to add one user name, it will take it, adding a second or third and it fails with aaa error user5 5, after adding the aaa new-model statement, it will do the same, one name, this is from the CLI
Reza Sharifi
What is the switch model you have and what IOS are you running?
Can you post the exact output of the command you apply and the error message?
isco IOS XE Software, Version 16.11.01
Cisco IOS Software [Gibraltar], Catalyst L3 Switch Software (CAT9K_LITE_IOSXE), Version 16.11.1, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2019 by Cisco Systems, Inc.
Compiled Thu 28-Mar-19 07:19 by mcpre
FIPS: Flash Key Check : Key Not Found, FIPS Mode Not Enabled
% Please answer 'yes' or 'no'.
Would you like to enter the initial configuration dialog? [yes/no]:
Would you like to enter the initial configuration dialog? [yes/no]: n
Would you like to terminate autoinstall? [yes]: y
Switch#config t
Enter configuration commands, one per line. End with CNTL/Z.
Switch(config)#username engineering privilege 15 secret Domino
Switch(config)#
Switch(config)#
Switch(config)#Switch(config)#username triplight privilege 15 secret Earth2wo
Switch(config)#$ER_RESET: User triplight failed attempts reset by console
*Aug 30 13:42:59.627: %AAA-5-USER_RESET: User triplight failed attempts reset by^ console
% Invalid input detected at '^' marker.
Switch(config)#username engineering privilege 15 secret Earth2wo
Switch(config)#username triplight privilege 15 secret D0mino
Switch(config)#username Matthew privilege 15 secret H0m2alone
Switch(config)#
*Aug 30 13:47:15.136: %AAA-5-USER_RESET: User Matthew failed attempts reset by console
Switch#config t
Switch(config)#
Switch(config)#
Switch(config)#
