06-17-2021 07:34 AM
I am receiving an error while trying to use the archive download-sw command. I have verified connectivity to my FTP server (ping and ran a successful "copy" command). I am upgrading a 3560-X running 12.2.55 to 15.2.4. Below is the output:
SW1#archive download-sw scp://<user>:<password>@<IP address>/Cisco/IOS/c3560e-universalk9-tar.152-4.E10.tar
Could not buffer tarfile...using multiple downloads
examining image...
%Error opening scp://<user>:<password>@<IP address>/Cisco/IOS/c3560e-universalk9-tar.152-4.E10.tar (No such file or directory)
%Error opening flash:update/info (No such file or directory)
ERROR: Image is not a valid IOS image archive.
I see examples of TFTP and RCP but is SCP or SFTP supported?
06-17-2021 07:50 AM
is this FTP or SCP ? FTP run standard port, SCP run secure port.
Try manually upload config from device to SCP server is this works ?
check below :
path correct
do you see any request in serer side from device ?
06-17-2021 11:12 AM
SCP/22
Yes, this works.
path correct
From WinSCP UI: /Cisco/IOS
File is located in that directory (file name: c3560e-universalk9-tar.152-4.E10.tar)
Yes from the logs I can see session open with user and session quickly close on the FTP server. Not sure if I have the right syntax or not.
06-17-2021 12:28 PM
Not sure if 12.2.55 supports SCP or SFTP. Here are several examples for 12.2.53 version but they are all pointing to TFTP
This example shows how to download a new image from a TFTP server at 172.20.129.10 and to overwrite the image on the switch:
This example shows how to download only the software image from a TFTP server at 172.20.129.10 to the switch:
This example shows how to keep the old software version after a successful download:
This example specifies the location of two tar images without having to specify the path each time:
This example specifies the location of three tar images without having to specify the path each time:
This example shows how to upgrade stack members 6 and 8:
06-17-2021 01:12 PM
path correct From WinSCP UI: /Cisco/IOS File is located in that directory (file name: c3560e-universalk9-tar.152-4.E10.tar)
Not from WinSCP
Fro router test copy running to scp server see if that works ?
as another post suggested, SCP support in 12.2. ( been used this IOS Long cant remember)
SW1#archive download-sw ? ( post what option you have?
Quick and Dirty i download simple TFTP to your Laptop copy the image and upgrade, rather making complicate things
06-17-2021 01:23 PM
Yes, id id copy from switch to FTP server. I logged into winscp just to verify path from my laptop. Yeah, I will just create a tftp server
Thank you.
06-17-2021 01:35 PM - edited 06-17-2021 01:36 PM
i am bit confused here. you mentioned here FTP, is this SCP or FTP ?
can you give me syntax of the copy ?
along with below command
show version from switch
dir
SW1#archive download-sw ? (if you type ? you get options) post complete message here
06-18-2021 08:01 AM
Sorry, I refer to it a s an FTP server when in actuality port 21 is not allowed only secure protocols SFTP, SCP.
06-17-2021 03:34 PM
Put a file in the file directory -- Any file. A text file is preferred.
Attempt to copy this file from the server to the switch and let us see what error message(s) pops up.
06-18-2021 08:44 AM
SW1#copy scp://10.100.249.18/Cisco/IOS/test.txt flash:
Source username [admin]? root
Destination filename [test.txt]?
Password:
%Error opening scp://root@10.100.249.18/Cisco/IOS/test.txt (No such file or directory)
I am able to copy my running config to the same directory (write) with this command:
SW1#copy run scp:/Cisco/IOS
Address or name of remote host []? 10.100.249.18
Destination username [admin]? root
Destination filename [/Cisco/IOS]?
Writing /Cisco/IOS
Password:
5682 bytes copied in 13.548 secs (419 bytes/sec)
Both Directories are set to 0755 (Read, Write, Execute for owner, root)
06-18-2021 08:50 AM
Use a different machine as the server.
06-18-2021 09:25 AM
I am now trying to access the file from a tftp server (different server). Similar results.
SW1#archive download-sw tftp://<IP address>/tftp-share/c3560e-universalk9-tar.152-4.E10.tar
examining image...
%Error opening tftp://10.237.160.250/tftp-share/c3560e-universalk9-tar.152-4.E10.tar (No such file or directory)
From TFTP server:
TFTP Error from <IP address> requesting tftp-share\c3560e-universalk9-tar.152-4.E10.tar: File does not exist
06-18-2021 06:18 PM
Ok, so both SCP and TFTP are saying the same thing. Check the directory where the file is stored and see if the filename is present. If the SCP/TFTP server is a Windows-based system, make sure the "hide file extension" option is disabled.
Then check if TFTP is pointing to the correct sub-directory or not.
If the problem still exist, try moving the file into a USB stick
06-21-2021 07:12 AM
06-21-2021 08:28 AM
Looks like the version is EOL i guess, you will not find from cisco site here.
may be google that .bin file you will see some download archive sites. or i least bother i use latest version to recovery in case anything go wrong as ROMMON recovery with 15.X version
