using cat93k to split wan connection and getting high packet loss
nflnetwork
hi we are splitting an ISP wan connection into a firewall and using 3 ports on the cisco cat93k .
ports 46,47,48
i have the 3 ports in access mode on vlan 100
spanning tree portfast
unfortunately the wan connection is not usable. seeing large packet loss.
if i move these 3 connections into a $100 netgear switch it works flawlessly.
what am i missing on the cisco?
we are doing this because the firewall is 2 units in HA mode and i needed to split the WAN connection . Pretty standard .
6 Replies 6
balaji.bandi
We need more information, where the packet Loss occuring. while leaving the Switch or FW ?
Can you provide configuration and example here ? along with your FW connection, what FW is this ?
as per my understanding here, switch is only Layer 2 simple access VLAN forwarding the Traffic to FW to take decision to split between ISP i guess here.
i only see here there may be some speed negotiation between Switch and FW or some missing config here.
wait for your inputs to understand more better.
BB
i am pinging the wan IP address, packet loss is on traffic coming in
fortigate 200, cisco is only being used as a splitter
correct
everything is set to auto
BB - WAN IP outside Fortigate (internet ) or is this IP configured on fotigate ?
can show output of packet loss ? - Fortigate is HA Mode right ? HA need Sync Link - how is HA connection ? what VLAN is this ?
BB
WAN interface on the firewall.
i see this in the logs
*May 3 21:19:05.809: %SW_MATM-4-MACFLAP_NOTIF: Host 0009.0f09.0002 in vlan 97 is flapping between port Te4/0/46 and port Te4/0/47
We only know Limited information as of now, as per your message you have only VLAN 100, now we see VLAN 97.
( I  advise you to post the Switch configuration)
Some recomendation to fix the issue :
1. find out that MAC Address belong to what device ?
2. Make sure you seperate the HA SYNC  Links Data VLAN for best practive.
BB
