Using DAC cable for keep-alive connection
michakushner
Community Member
I understand from posts that although it is possible to use Mgmt port for keep-alive between Nexus 3524P switches, although it is not recommended.
This means buying two (or four) copper SFP's for keep-alive connection.
Is it possible to use a DAC (Direct Attach Cable) cable between the switches for keep-alive?
A DAC cable is much cheaper than two SFP's.
Thanks in advance
lucasfreitas83
Level 4
Level 4
Hello michakushner,
No problem to use DAC with keep-alive, I used in a lot environments in two Nexus and work fine.
Caution only of matrix, cable X switch model.
https://tmgmatrix.cisco.com/?npid=677
Please rate and mark posts accordingly if you have found any of the information provided useful.
It will hopefully assist others with similar issues in the future.
Best regards,
Lucas Freitas
Reza Sharifi
That is correct. DAC cable is much cheaper and DAC cables are usually compatible with Nexus.
I usually get them here:
 https://www.fs.com/
They are reasonable and usually work with Cisco with no issues.
lucasfreitas83
Level 4
Level 4
Hello michakushner,
Best regards,
Lucas Freitas
