Using DNS servers with switches
tariqhasan9
Hi All,
I have some of the switches in my company configured for DNS as below:
no ip domain-lookup
ip name-server 10.100.10.35
ip name-server 10.100.10.36
My first question is, as domain-lookup has been disabled using "no ip domain-lookup", would the following lines specifying the name-servers have any affect?
As far as I understand, for the switch to be able to use the DNS servers I need to enable "ip domain-lookup", am I correct in thinking that way?
Second question, if I have the config as below:
ip domain-lookup
What happens when for example if I type "ping abc" and if my name-servers are not able to resolve the name or in case the name servers are unreachable, would it behave as if no name servers were configured and try to resolve it by itself and I'd have to wait 1 minute or 2 before I can do anything?
Would anyone be able to clarify this for me?
Many thanks,
Tariq
Daniel McDavid
Yes, the 'no ip domain-lookup' will prevent the switches from attempting to resolve. The 'ip name-sever X.X.X.X' do not have any affect because you've told it not to resolve addresses. You need to issue a 'ip domain-lookup' in order to resolve domain names, as you have suggested. If your name servers cannot resolve the address, you will have to wait for the lookup to timeout. I would disable domain-lookup if you aren't using it because any time you mistype something like exif instead of exit, your switch will attempt to resolve that and you'll have to wait for a timeout.
Thanks very much for the clarification Daniel. Appreciate it.
