Using GLC-T modules in SFP+ ports
Hi colleagues!
Does somebody know can i use Cisco GLC-T module (which is SFP module for copper connections) with SFP+ ports?
For example if i will by WS-C3850-12XS (with 12 SPF+ports) will be i able to create 1 Gigabit copper connection?
Unfortunately i can no find any disproof or proof about that.
Thanks you in advance!
Furose M
Level 3
Level 3
why not? the document is here:
http://www.cisco.com/c/en/us/td/docs/interfaces_modules/transceiver_modules/compatibility/matrix/GE_Tx_Matrix.html#_Toc450806443
Furose M
Level 3
Level 3
Thanks!
It enough for me
