Bookmark
Subscribe
1907
Using Kron to Automate VLAN changes.
brian.plue
I am looking to automate the process of changing a vlan for an employee who requires access to an outside line seperate from our corporate network. This employee only works Mondays from specific hours and I am trying to use Kron to change the vlan back and forth on his port during those hours.
The corporate network is vlan 1, the outside network is vlan 30.
Here is what I have for configuration:
kron policy-list AccessStart
cli interface gig 1/0/35
cli switchport access vlan 30
kron policy-list Access End
cli int gig 1/0/35
cli switchport access vlan 1
I have tried with "config t" and without (Obviously I am scheduling with the Kron occurance command) I have back-ups working using Kron but can't make this work. Is there anything I am missing?
srereddy
There are some limitations with 'Kron'. What is your IOS release? Some versions dosent support interface mode commands (yeah i know, unfrtunately sometimes unsupported commands still be parsed in IOS).
Assuming it supports......lets take a look complete config....can u paste it here including the Kron occurence?
It should look like -
cli interface gig1/0/35
kron occurrence AccessStart at 9:00 Mon recurring
version 12.2
no service pad
hostname B1
boot-start-marker
boot-end-marker
enable password XXXXXXXXXXXXX
no aaa new-model
switch 1 provision ws-c2960s-48lps-l
crypto pki trustpoint TP-self-signed-2524761216
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2524761216
revocation-check none
rsakeypair TP-self-signed-2524761216
spanning-tree mode pvst
spanning-tree portfast default
vlan internal allocation policy ascending
interface FastEthernet0
no ip address
shutdown
interface GigabitEthernet1/0/1
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
switchport access vlan 121
switchport mode access
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
interface GigabitEthernet1/0/25
interface GigabitEthernet1/0/26
interface GigabitEthernet1/0/27
interface GigabitEthernet1/0/28
interface GigabitEthernet1/0/29
interface GigabitEthernet1/0/30
interface GigabitEthernet1/0/31
interface GigabitEthernet1/0/32
interface GigabitEthernet1/0/33
interface GigabitEthernet1/0/34
interface GigabitEthernet1/0/35
interface GigabitEthernet1/0/36
interface GigabitEthernet1/0/37
interface GigabitEthernet1/0/38
interface GigabitEthernet1/0/39
interface GigabitEthernet1/0/40
interface GigabitEthernet1/0/41
interface GigabitEthernet1/0/42
interface GigabitEthernet1/0/43
interface GigabitEthernet1/0/44
interface GigabitEthernet1/0/45
interface GigabitEthernet1/0/46
interface GigabitEthernet1/0/47
interface GigabitEthernet1/0/48
interface GigabitEthernet1/0/49
interface GigabitEthernet1/0/50
interface GigabitEthernet1/0/51
interface GigabitEthernet1/0/52
interface Vlan1
ip address x.x.x.x x.x.x.x
interface Vlan30
no ip address
interface Vlan121
description OSS
no ip address
ip default-gateway x.x.x.x
ip http server
ip http secure-server
kron occurrence backupSchdule at 23:00 Sun recurring
policy-list backup
kron occurrence AccessStart at 8:30 Mon recurring
kron occurrence AccessEnd at 17:30 Mon recurring
policy-list AccessEnd
kron policy-list backup
cli write
cli show run | redirect tftp://x.x.x.x/b4.cfg
kron policy-list Acess Start
cli config t
kron policy-list AccessEnd
cli int gig 1/0/35
logging trap critical
logging x.x.x.x
snmp-server community xxxxx RW
snmp-server community xxxxx RO
line con 0
line vty 0 4
password xxxxxxxxx
login
line vty 5 15
password xxxxxxxxx
login
end
Cisco Catalyst 2960S using the 12.2 software
