Using Route-Map Questions
allen.malanda_2
Level 2
Level 2
I want to understand the route-map command purpose. Through my research, it seems like it can only be used with dynamic routing protocol. I have two static route entry in my route. If the source destination of the traffic is 10.1.0.24, I want to route through 10.1.1.1. If the source destination is 10.1.0.25, I want to route through 10.1.1.2. Can I accomplish this with route-map command?
Jon Marshall
Malanda
access-list 101 permit ip host 10.1.0.24 any
access-list 102 permit ip host 10.1.0.25 any
route-map PBR permit 10
match ip address 101
set ip next-hop 10.1.1.1
route-map PBR permit 20
match ip address 102
set ip next-hop 10.1.1.2
int fa0/0
ip address 10.1.0.1 255.255.255.0
ip policy route-map PBR
Jon
Jon Marshall
Malanda
int fa0/0
Jon
andrels
Level 2
Level 2
I suspect you could use PBR/Route-map to achieve such solution.
