using same hsrp group id
fawad.alam
I am configuring HSRP on two 6500 MSFC SUP2. There is a limit of 16 HSRP groups on this platform. I am configuring new SVI with HSRP on these switches..I think I can configure one of the existing HSRP group ID that is in use already.
Is there any limitation/ drawback ? I have to configure HSRP as I cannot have a Single Point of Failure.
ANy comments!!!
Unless you are bridging between VLANs then you can re-use the HSRP group numbers:
interface Vlan10
ip address 10.1.1.253 255.255.255.0
standby 1 ip 10.1.1.254
interface Vlan20
ip address 10.1.2.253 255.255.255.0
standby 1 ip 10.1.2.254
interface Vlan30
ip address 10.1.3.253 255.255.255.0
standby 1 ip 10.1.3.254
They will all share the same virtual MAC address, however as the CAM tables are per-Vlan there should be no issues. If you bridge between Vlans then this is where it won't work.
Andy
